AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
BikeBandit
Old 02-20-2008   #31 (permalink)
Favorite Bike: 2007 Mulberry SM
MackDaddy's Avatar
Other Motorcycle: http://tinyurl.com/3ayfq2
Originally Posted by NewOldSkool View Post
MackDaddy, you know if they are the same length as the stock springs for the Bonnie?
That I can't answer. My SpeedMaster specific Progressive springs (11-1145) were a "touch" longer than my OEM straight rate springs. I'm talking less than .5" but didn't take an exact measurement.
HTH
2008 Kawasaki Versys
http://public.fotki.com/mackdaddy/va...wasaki-versys/
MackDaddy is offline   Reply With Quote
Old 02-20-2008   #32 (permalink)
$66.79 including shipping - thanks for finding those!
How hard is the swap gonna be? I guess I'll find out!
Mattrat is offline   Reply With Quote
Old 02-20-2008   #33 (permalink)
Favorite Bike: 06 Bonneville Black
NewOldSkool's Avatar
Well if they are longer then OEM by a touch it is fine then, right? Because if they are shorter then you would have to make spacers, at least that what I understand. As far as the rear shocks, yeah talked to my dealership again, and he said they were running a special for the rear shocks and that they were very good quality for what he can tell.
Iraq is stupid!!!
NewOldSkool is offline   Reply With Quote
Old 02-20-2008   #34 (permalink)
MackDaddy's Avatar
Talking
Not a problem at all. The swap is time consuming, but fairly easy. I just did mine last Friday.
Old 02-20-2008   #35 (permalink)
MackDaddy's Avatar
I don't see any problem with them being a bit longer. Mine actually stated reusing the OEM spacers, but I added Thruxton adjustable preload fork caps. I had to make PVC pipes that were 25mm shorter than the OEM steel units. Still no big deal. If you're not doing as I did, you'll reuse the OEM spacers... plug-n-play!
Jim
hagon road shocks & progressive fork springs V`s just hagon 2810 adjustable shocks typhoo Twins Technical Talk 3 11-03-2007 12:24 AM
progressive shocks Rube Twins Talk 7 04-12-2006 08:35 PM
Progressive Shocks biker1059 The Rocket Science Forum 6 01-19-2006 01:33 AM
Progressive shocks Slick The Rocket Science Forum 3 08-27-2005 12:43 AM
Progressive Shocks Howard_inGA The Rocket Science Forum 12 08-12-2005 09:01 AM
