lubing brake caliper pins - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 02-15-2008, 10:26 AM Thread Starter
Main Motorcycle: 2006 thruxton
what kind of lube, if any should be used?
bronsonj is offline
post #2 of 6 (permalink) Old 02-15-2008, 10:32 AM
Main Motorcycle: My Bonneville of course
I would leave em dry. Any lube could migrate when it heats up and potentially contaminate the pads.
Never lubed em and never had any issues from running dry.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline
post #3 of 6 (permalink) Old 02-15-2008, 11:37 AM
If they are getting corroded and dry looking like you're afraid they'll become seized. just rub some grease onto them and wipe off all the excess. That should improve the sitch w/o leaving any grease to worry about.
dazco is offline
post #4 of 6 (permalink) Old 02-15-2008, 12:30 PM
Main Motorcycle: 05 Black Speedmaster
I have used a thin film of white lithium grease and/or graphite with success.
Normandy is offline
post #5 of 6 (permalink) Old 02-15-2008, 01:05 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
There is such a thing as "brake grease"
Here's what I've been using for the past 10 years or so, on several bikes. One tube should last two or three lifetimes.
Unfortunately, some of the directions have been smudged off the back of the tube, but here's how I use it.
- light coat on the pins, wipe off excess.
- light coat where the pads slide in the caliper, wipe off excess.
- very light coating rubbed onto the backing plates of the brake pads.
The last item is the one that eliminates the brake squealing, which is caused by a high frequency vibration (in most cases) between the pad and the caliper piston.
Just keep it off the brake pad lining. That should go without saying
Here's part of the fine print from the tube. "...... a specially formulated synthetic grease containing molybdenuim sulfate graphite, and TEFLON. Keeps critical parts in calipers free for optimum braking efficiency. Helps prevent caliper binding, sticking, vibration, and squeal. Extremely high temperature features make certain this lube will not melt or run off caliper assemblies, self adjusters, and drum brake systems....." And that's where the directions vanish!
If the thought of having any form of grease on or around your brakes disturbs you, ignore this post. I'm not recommending it, only describing what I do.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #6 of 6 (permalink) Old 02-15-2008, 09:21 PM
I use a very small amount of "brake caliper grease" in the little packets at the checkout in the auto parts store. A little goes a long way.
Marty
Baltobonneville is offline
rear caliper slider pins villageidiot T3 Sport / Touring Forum 10 01-29-2008 02:55 PM
Brake Pins OGSpeed3 T3 Sport / Touring Forum 7 04-17-2007 07:43 PM
Brake Pins OGSpeed3 Speed Triple Forum 2 03-23-2007 01:57 PM
Brake Caliper HKTon-Up Club Cafe' 22 02-01-2006 07:57 AM
brake caliper triumphtimes Sprint Forum 3 02-08-2005 08:30 PM
