Dunlop Rear Tyre - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-05-2008, 09:40 PM   #1 (permalink)
Favourite Bike: Triumph Thruxton
itcha's Avatar
Dunlop Rear Tyre
Swapping out my rear tyre and I can get a good price on a Dunlop 140/70/17.
Is this tyre okay to run with, would it change anything over the stock size 130/80/17.
Also would this be a better tyre then the Bridgestone Battleaxe 45 in stock size.
Thanks.
itcha is offline   Reply With Quote
Old 02-05-2008, 10:45 PM   #2 (permalink)
Tyre
Got the same size on mine & works super!! I would do both as the mis matching on some tires has some handling differences. I did another BS on the back till its done & then a new set of whatever is the best deal @ the time. Matched sets work better together! The size is rite on tho. Looksbetter & handles a little better as well. Different tho so takes getting used to. I almost dropped the bike in the garage because the height difference made the side stand different angle w/ the larger rear tire when I 1st got it home! Do a matched set or another B45 in the size you said & then a new matched set? Workin good for me!
CAPT D
Old 02-05-2008, 11:53 PM   #3 (permalink)
itcha's Avatar
Cool,
I think I will get the Dunlop 140/70/17 fitted and if I have any handelling issues I'll get the front done in a Dunlop also. Hopefully won't have those issues as front tyre still has plenty of tread left.
Does the Dunlop's get good mileage, I mainly commute and require more mileage over super sticky tyres that wear quickly.
Cheers.
Old 02-06-2008, 11:27 AM   #4 (permalink)
Favourite Bike: Bonnie black
Haggis's Avatar
Other Motorcycle: Sprint RS
There may be no handling issues...
but, your bike will definately ride better with matching tires.
Haggis is offline   Reply With Quote
Old 02-06-2008, 11:36 AM   #5 (permalink)
Favourite Bike: Triumph Bonuxton
DrewDesign007's Avatar
Other Motorcycle: N/A
Extra Motorcycle: N/A
What do you guys like for channelling water away?
Scored as a rocker!
75% rocker - 50% mod
DrewDesign007 is offline   Reply With Quote
Old 02-06-2008, 12:14 PM   #6 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
Dunlop makes several tire models. I've run their GT501 tires in 100-90/19 on front and 150-70/17 on the rear for the past two riding seasons. I like the way these tires tour as well as how they handle on the twisty back roads. I've run these in wet and dry conditions, and they perform well.
You need to make sure that any oversize tire you install on the rear is designed to work with a 3.5" wide Triumph rim. Some aren't, and are intended for a wider rim.
Here's the link to the GT501 section of the Dunlop web site. If that isn't the model you're using, browse around their site and find the model you're intending to use.
http://www.dunlopmotorcycle.com/tire..._tire.asp?id=8
Bob
Note - I may drop to a narrower rear tire next time, just to see how much quicker the bike will roll from side to side. It should change direction quicker and easier with the narrower tire.
Old 02-06-2008, 03:02 PM   #7 (permalink)
Haggis's Avatar
I love Metzlers
On my RS, replacing the Bridgestone with Metzler transformed the handling, and added a large degree of safety in the rain and wet. I've also ridden on frozen roads (black ice - not recommended btw) and stayed upright.
The Bonnie isn't as fast and powerful, so the tires seem to be somewhat less of an issue, but I trust Metzler's....and that calms the little voices in my head:
Old 02-06-2008, 05:17 PM   #8 (permalink)
MAR
Favourite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco Laverda Mir
I was just wondering why you haven't given Perelli Sport Demon's any thought? I had them on my thruxton and can't say enought good things about them.
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Dunlop D220 rear, cheap! T3 Sport / Touring Forum 1 12-15-2006 07:57 PM
rear tyre padwah Twins Technical Talk 0 07-24-2006 11:19 AM
Dunlop Qualifier Sports tyre DaveM Sprint Forum 13 05-02-2006 12:00 AM
DUNLOP 250/40 x 18" Rear Tyre SteveRed The Rocket Science Forum 6 03-01-2006 07:11 AM
Rear tyre Speed Triple Forum 3 11-10-2004 01:17 AM
