Motorcycle.com
Closed Thread
Old 02-01-2008   #1 (permalink)
Favorite Bike: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
new choke knob
Just poking around the shop and looking for an interesting choke knob.....
Ended up using a .45 cal hollow point bullet for one (see pic)
Fairly easy mount, drill the hollow point out using a 3/16 drill (same size as shaft on existing knob) but you need to go VERY slow so as not to impart any heat to the bullet.
Once you have drilled through, empty the powder out of the bullet by inverting and shaking till no more comes out.
The primer is the only hitch....since there is no safe way to remove it, and removing it would cause an unsightly hole, I just left it in...it should be (cross your fingers) okay since there is really not enough heat getting to it to cook it off.
Once empty, take the factory knob off, sand or grind the end of the shaft off to get the plastic off and insert into the hole you drilled. It will seat just fine leaving about a 1/8 gap between the end of the bullet to the mounting nut.
DO NOT attempt to pound the shaft further into the bullet.
DO add a dab of epoxy to the end of the shaft which will set it quite nicely...
I wouldn't do this unless you are completely familiar with firearms and reloading. You can get hurt if you set the round off.....
Let me know what you think!
bill
Mods: snorkel removed, bafflectomy, jets out 3 turns, summer screen, cortec tank/saddlebags, Bella Corse Highlander bars,Modre peg lowering kit,Drag specialties mini tach, D9 bracket.
koifarm is offline
Old 02-01-2008   #2 (permalink)
Favorite Bike: Triumph Bonneville 2007
FrankBlack's Avatar
You are quite mad Bill. Love the idea!
Silver Bonneville 2007
Burgess style silencers/45 pilots/145 mains/Turns:0.75L&1.25R/50 mpg avrg/FARK/Latest DYNO
FrankBlack is offline
Old 02-01-2008   #3 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
I have another good idea! Take a pipe, close off one end, fill it with gun powder, close off the other end so it is good and sealed and then drill the hole in the center for the fuse to go in! No problems with that idea either - right?
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline
Old 02-01-2008   #4 (permalink)
Favorite Bike: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a Speed Triple
Guess your Bonnie is as fast as a Bullet now.
'04 T100 Black and White (because that is the only colour to wear with a Dinner Jacket)
AI removed, TORS
engine dresser bars, grab rail, flyscreen, Triumph leather panniers and tank bag
lovin' ev'ry minute of it
TB-T100 is offline
Old 02-01-2008   #5 (permalink)
FrankBlack's Avatar
Just thinking, how about a bullet drilled on one side so that it faces towards the front of the bike. It would handle better and I imagine look great. But for goodness sake, be careful!
Old 02-01-2008   #6 (permalink)
koifarm's Avatar
reply
Yea, Frank, i had thought about that....only problem is getting it fixed on the shaft of the attachment pin. maybe if you drilled the hole, drained the powder, and filled it entirely up with epoxy, then inserted the shaft and waited for that to set......it's been my experience though, that epoxy ain't gonna hold much on a slick metal surface so it would likely begin to rotate after a bit of use...
I think it would look better that way but attachment becomes an issue in that case...alternately with that the really safe process would be: remove the lead bullet with a bullet puller, carefully remove the primer using a hand loading tool with the correct primer punch (they are designed NOT to set off the primer) then perhaps silver solder the pin/mounting screw into the case then replace the lead with another die on the loading machine.....(don't have one or i would have done it that way.)
It's easy to use in the present configuration.
Hedge, I feel your pain, if you know anything about ammunition, you know, as well as I, it's a calculated risk and one I'm not particularly worried about. it would take one helluva pop to get the primer off....and likely you would bend the choke lever since it's kinda thin metal.
In the event the primer did go off, the bullet would stay in place, the casing would pop off and at worst hit the inside of your left leg. In my case my kevlar pants cover that area anyway but I figure there is only a 10% chance of the primer going off....
Thanks for y'alls input...
Bill
koifarm is offline
Old 02-01-2008   #7 (permalink)
Favorite Bike: My 2007 Bonnie T100 B & W
barneys's Avatar
Other Motorcycle: One day................
Extra Motorcycle: If only.............
Live dangerously don't you!!!
I'd give up beer, but I'm no quitter
barneys is offline
Old 02-01-2008   #8 (permalink)
Loxpump's Avatar
You know what they say at the beginning of the show Mythbusters. Folks don't try this at home, we're trained professionals.
Stop Global Whining!
Semper Fi!
Loxpump is offline
Old 02-01-2008   #9 (permalink)
mjsmilford's Avatar
after you drill out the lead, why don't you just put the bullet in your pistol and shoot off the primer? it won't change the look that much and you'll know for certain your safe
2007 triumph thruxton
1982 yamaha XJ750 maxim
1969 350 SS camaro
mjsmilford is offline
Old 02-01-2008   #10 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
yea be carful with useing live primers they go off easyer then the powder .I hope you didnt really drill a live round lol
mikeinva is offline
Closed Thread
need advice on the choke knob lsettle Twins Technical Talk 4 08-29-2007 08:57 PM
Choke knob removal OgmernIWulfsail Twins Technical Talk 4 04-24-2007 04:30 AM
$.99 Choke knob GrayMitchell Twins Technical Talk 15 03-11-2007 12:32 PM
Custom Choke Knob Whitehurst Club Cafe 4 02-12-2007 01:30 PM
Knob below Choke jaysray Twins Technical Talk 3 12-09-2006 02:10 PM
