Old 02-01-2008   #1 (permalink)
Orpheus's Avatar
tips/tricks for front brake replacement?
This weekend, I'm going to replace my front brake and pads (EBC). Anything I should watch out for during the process? Also, if anyone has torque figures handy, I'd appreciate it.
Old 02-01-2008   #2 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
yes, there is a must
pop the pistons out of the calipers and scrub them clean with brake fluid and a copper chore boy pad, and change the fluid as you re bleed. make sure to clean the surface of the caliper real well where the pistons come out. put smear of of pad lube on the backs. and flip the two square seals over carefully,so you do not nick them, or better yet replace you can get them much cheaper from the honda shop if you take them in they will match them up for you, (honda uses this caliper on some shadows) the kawi dealer might also have them as this caliper is a common for them as well. lube the pad pin with just a little grease as well. Just make sure you have a vacuum bleeder around before you start.
dot 4 fluid
caliper bolts about 26 foot lbs w blue locktite.
if you just push the pistons back in dirt will drag back past the seals and air will get back into the system slowly, when the bike sits and you will not have consistant braking and soft feel, these calipers have no dust shield.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 02-01-2008   #3 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
Another Noteworthy piece of information that I just copied and pasted into a Word document and filed away under "Tips for front brake replacement"
Thx Jon
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 02-01-2008   #4 (permalink)
Favorite Bike: 2005 Bonneville Black
I highly recomend a small butane torch to heat up the disc bolts before removing them.
I had one handy but wanted to try to do it without heat....almost striped the bolt head.
USE HEAT...not a lot...but do use it!
2005 Bonni Black; Reverse Cones, Pods, No AI, 145, 42, Thrux Needles, 1.75 Turns Out, Iridium's, EBC Brakes, Speed-Bleeders, and a pile of stock parts.
SCL18 is offline   Reply With Quote
Old 02-01-2008   #5 (permalink)
Hedge's Avatar
Another good useable piece of information that I added to the bottom of my document!
Thx -
Old 02-01-2008   #6 (permalink)
Favorite Bike: Black 06 Thruxton
Other Motorcycle: Red 01 SV650S
Smile Torque Specs
Banjo Bolts = 25 Nm = 19 ft/lb (9/16" on my bike, not metric)
Brake Pad Pins = 18 Nm = 13 ft/lb (5 mm Hex)
Front Brake Caliper Bolts = 28 Nm = 20 ft/lb (12 mm)
Front Brake Rotor Bolts = 22 Nm = 16 ft/lb (6 or 8 mm Hex)
Bleed Vavles = 5 Nm = 45 In/lb (8 mm)
Needed if replacing Rotor
Front Axle Nut = 60 Nm = 45 ft/lb (24 mm)
Front Axle Pnich Bolt = 27 Nm = 20 ft/lb (6 mm Hex)
Front Axle Pinch Bolt for American/Speedmaster = 20 Nm = 15 ft/lb (size =??)
Hope this helps.
Tusitala - Mt Vaea
SHILOH is offline   Reply With Quote
Old 02-01-2008   #7 (permalink)
Favorite Bike: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a Speed Triple
Thx Jon
Hedge, will you share your library of useful information with the rest of us, please? I understand that it is mainly comprised of stuff written here at triumphrat.net, but it sounds as if you have done a good job of compiling it. Maybe you could post it in the blog-section. Or do you email it to those that ask? In which case: could you please email it to me?
'04 T100 Black and White (because that is the only colour-combination to wear with a dinner jacket)
AI removed, TORS
rebuilt front (valves, springs, etc), Öhlins shocks
engine dresser bars, grab rail, flyscreen, Triumph leather panniers and tank bag
TB-T100 is offline   Reply With Quote
Old 02-01-2008   #8 (permalink)
Hedge's Avatar
That is something I can share here on the the Rat. However, I have all these pieces information copied and pasted into Word documents and the documents are in different folders under one master folder called Triumph. I guess I could just zip a bunch of it up and email them out to anyone that is interested. But as you said - it is no mystery or secret knowledge; it is merely anything that I thought could be potentially useful in a future situation.
I'm happy to share that and anything else that is useful . . . unfortunately for you Wisenheimer's I got rid of my porn collection years ago, just nothing out there anymore that is new or unusually interesting that hasn't been seen before, except for that Ugly Monkey's Rear End that I floated around in a few places!
Just PM me if you want something.
Old 02-01-2008   #9 (permalink)
Orpheus's Avatar
Thanks for all of the info!
Hey, what happened to the tech wiki? I can't seem to find it anymore...
Old 02-01-2008   #10 (permalink)
TB-T100's Avatar
Buried in the Blogs-section.
AI removed, TORS
Install Tips/Tricks for Triumph Hugger BinarySpeed4 Triumph SuperSports 6 01-28-2008 10:07 PM
Front brake replacement / any thoughts Pauley Twins Technical Talk 3 05-14-2007 11:31 PM
Front Brake Pad Replacement T100Aust Twins Technical Talk 8 09-04-2006 06:30 PM
Tank removal tricks or tips? Tee-Dub Speed Triple Forum 10 07-26-2006 10:35 AM
Cleaning the bike...tips and tricks to share??? Dukester Modifications & Workshop Talk 16 08-16-2005 01:10 PM
