Old 01-28-2008   #1 (permalink)
Favorite Bike: Triumph Bonneville
Poor Autonomy - Bonnie Black
I bought my 05 Bonneville Black last week and so far haven't been able to ride it over 100 miles without having to switch to reserve. When i go fill her up, I can only get about 2.2 gallons in before topping off. Something is odd here. I do get a good mpg but it seems as if i can't use a third to a half of the fuel in the tank. I've seen this reported before but no explanation given so far. Can anyone help with input/advice? Much appreciated!
Ride safe,
Jay
Update - a quick search on this site and I found this reply to a post about fuel autonomy on a Tiger
Originally Posted by alfacliff View Post
I had the same problem with my bonnie, you have to lean the bike way over to the left to get the gas out of the right side of the tank over to the left side where the fuel pickup is. mine had lots left in the right side but was dry on the left. there should be two fuel taps, one on each side.
cliff
So along with an eventual fuel pickup readjustment, I will try this next time and see how much farther I can go before switching to reserve. Will update this posting. Thanks everyone for the great input!
piffs is offline   Reply With Quote
Old 01-28-2008   #2 (permalink)
Favorite Bike: 2007 Bonnie T100
Glider's Avatar
Seems you are getting about the mileage most report (40 to 50 mpg depending on conditions), but I usually get about 125 miles before reserve. Mine is a 2007.
Just a thought...are you filling it up while on the side stand or center stand? Since the filler is on the right side and the side stand leans to left, I assume you would get a little more in on the side stand.
If it wadn't this it'd be somethin' else
Glider is offline   Reply With Quote
Old 01-28-2008   #3 (permalink)
Favorite Bike: 04 Daytona 955i/02 Bonnie
Other Motorcycle: 04 Daytona 955i/02 Bonnie
the tank wraps around the backbone of the frame with out any provisions of leveling the fuel from side to side...
the tank on the bonnie is also fairly small with a large reserve.
reserve doesn't mean "get fuel immediately", it's just a way to tell you to pay attention...you're getting low.
zam70 is offline   Reply With Quote
Old 01-28-2008   #4 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
that is kinda strange mine gets about 135 to 145 to reserve but mine takes more gas then yours dose makes me wonder if the pick up in your tank is kinda 1/2 pluged up or is higher then mine.You might take it out of tank and check it.
Old 01-28-2008   #5 (permalink)
Favorite Bike: Was 2006 Black Bonneville
oldmanjob's Avatar
I agree with mikeinva that it might be a pickup problem as my 06 Black Bonnie goes 140 miles before turning to reserve
John 14:6 KJV
Black Bonnie - 06
Looking back to the good old days is not the way out. Looking up to the God of All the Days is. (Vance Havner)
oldmanjob is offline   Reply With Quote
Old 01-28-2008   #6 (permalink)
Favorite Bike: '06 T100
road_dog's Avatar
After I fill up (level with or slightly above the small hole recessed below the main opening) I'll use right at 3 gallons of fuel before I need to switch to reserve. So the 2.2 gallons you're claiming does seem a little odd, unless you're not filling your tank completely.
Phil (road dog)
Click on the Image
for Larger Picture
road_dog is offline   Reply With Quote
Old 01-28-2008   #7 (permalink)
Thanks for the quick input, Glider and also Zam. I knew that about the way the tank sits on the frame. But the reserve is supposed to hold aprox .79 gallons, not half the tank for a 4.4 gal. max capacity. So I'm still a good 1.4 gal. short which would put me in the 150-180 miles before reserve range and that seems to be what most of you are getting. Now the mpg is very good, no questions abot that, and I do fill up on the side stand and then level up to make sure it's actually full.
Ride safe!
Jay
_______________________________________________
05' Bonneville Black
San Diego - California
Old 01-28-2008   #8 (permalink)
Seems very plausible. 1.4 gallons is a lot of fuel not to use up. Thanks for the input, Mikeinva!
Ride safe!
Jay
Old 01-28-2008   #9 (permalink)
Favorite Bike: Triumph Bonnie T100 2007
Other Motorcycle: Suzuki Savage
Extra Motorcycle: A Vincent (I wished)
Mine doesn't go much past the 100 mile mark without going to reserve
A day without riding is like a day without beer.
2007 T100 with D&D cans, rejet, Dart Flyscreen, Ohlins on the back and Works Progs in the front. Very loud F*** Off horn. Oh and turn signal bleeper to remind me to turn them off.
SteveRocket is offline   Reply With Quote
Old 01-28-2008   #10 (permalink)
Milage
Your milage isnt too far off. Me thinks you are not filling it all the way or something w/ the petcock? I get 125-130 before reserve- depending on my right hand! I got crappy milage 1 time & someone here said "because of winter gas- less milage" I laughed then came back humbly as he was probably rite. I am in Fla but who knows what gas you are getting? Coulda been a "winter blend" ? Ethanol blend is known to give less milage. Check your petcock or tip her over to the right then keep pumping? No biggie!!
CAPT D
My Poor Bonnie fidhle Twins Talk 7 09-16-2007 10:26 PM
Poor Bonnie SCL18 Twins Technical Talk 20 07-17-2007 02:43 AM
Poor man's black exhaust Nathan Twins Technical Talk 1 02-16-2007 05:29 PM
Put up pics of my standard bonnie/thrux/black bonnie mutation faffyface Twins Talk 12 08-09-2005 11:40 AM
Photoshopped Pic of Black Rims on Bonnie Black for Convict derek985 Twins Talk 24 06-24-2005 09:55 AM
