Motorcycle.comTrident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
BikeBandit
Old 01-21-2008   #1 (permalink)
Mike's XS mini-speedo light help
I installed my speedo and tapped into the low beam wire and the ground. light works great until you turn on the headlight to bright. Can anyone tell me how I can remedy this problem?
2005 Bonnie Black
jcline8 is offline   Reply With Quote
Old 01-21-2008   #2 (permalink)
Loxpump's Avatar
I tapped the ground wire on the headlight plug for the ground, but the gauge light wire I just found a wire that was hot with the ignition on. Check it with a meter or test light but I think when you switch to high beams the other wire is hot to light the high beam filament, and not the low beam filament. Meaning I don't believe both are filaments ever on at the same time. I've got my bucket off to get it powder coated and plan on cleaning up my mini gauge wire mess somewhat, especially the diodes. I did notice that all my wires for my speedo are connected to one OEM plug in the headlight. I plan on taking good pics as I go.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Two for the road - new mini speedo ignition relo brackets D9 Twins Technical Talk 19 01-13-2008 07:10 PM
Mini Speedo/Tach thenning Classic, Vintage & Veteran 1 10-14-2007 09:38 AM
UK Mini Speedo oldgimmer Twins Technical Talk 0 09-01-2007 09:24 AM
light in speedo lefty290962 The Rocket Science Forum 4 04-22-2007 07:47 AM
Mini-Speedo tba-golfer Twins Technical Talk 20 03-18-2007 11:20 AM
