Old 01-21-2008   #1 (permalink)
Favorite Bike: my '05 Bonnie Black
neuroboy74's Avatar
Other Motorcycle: right, i wish. . .
preload adjustment
is there a specific kind of spanner wrench i need to get to adjust preload on my shocks? is it the same tool for all shocks? do i just have my head up my arse and a spanner wrench is the wrong thing to use altogether?
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline   Reply With Quote
Old 01-21-2008   #2 (permalink)
bendavanza's Avatar
The spanner is sort of a hook shape and is maybe not an exact match for every shock but should be usable between most brands.
http://images.google.com/images?q=sh...-8&sa=N&tab=wi
This link to a google image search should explain quite a bit.
You could also make your own tool without too much trouble, or modify another tool. If you're worried about scratching up the shock use a rag.
I've used all kinds of things in a pinch.
-Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 01-21-2008   #3 (permalink)
Favorite Bike: 2007 Bonneville T100
Other Motorcycle: 2006 Kymco People 250
With the stock shocks on my '07 T100 a hex key wrench works fine. Just find one that fits the hole in that silly adjuster thingy. I can't remember the size of the one I used.
When/if you buy a good set of aftermarket shocks, they should come with a tool that fits their own adjustment mechanism. Meanwhile, the hex key wrench is a decent no cost solution for the stockers.
Paul
2007 Triumph Bonneville T100, Tors, xAI, xSnorkel, 120 mains / 1 shim, 40 pilots, 3.0 turns, NH Bellmouth, Works Performance suspension, National Cycle Deflector DX, Scrambler Gel Seat
Pauljo is offline   Reply With Quote
Old 01-21-2008   #4 (permalink)
Favorite Bike: Bonneville 750cc T140V
Other Motorcycle: Hinkley fake Bonnie T100
A screwdriver or bar that's 6mm diameter or a bit less will do the job. No need for any 'special' tools.
English_Spanner is offline   Reply With Quote
Old 01-21-2008   #5 (permalink)
Other Motorcycle: '01 Goldwing 1800
Extra Motorcycle: '03 SuperHawk 996
+1 on the hex key. What I've been using...
Lance
Thruxtonian is offline   Reply With Quote
Old 01-21-2008   #6 (permalink)
neuroboy74's Avatar
they're actually stock ZRX shocks and are gonna require something like a spanner wrench. . . thanks for the replies.
Old 01-21-2008   #7 (permalink)
Favorite Bike: 1968 bonneville
tspapa's Avatar
Other Motorcycle: 2007 blk/wht bonneville
How about a lg pipe wrench?
I have only been drunk twice...the 60s & 70s
2007 T100,Blk/Wht,Ai removed,D&Ds,Snorkel out,restrictor plate out/one shim/ 132mains/40 pilots/3 turns
tspapa is online now   Reply With Quote
Old 01-22-2008   #8 (permalink)
Favorite Bike: 05 T100
ZRX's probably come with the tool required, do you have any mates with a ZRX? They look to me like they need what we call a "C-spanner", but you guys in the US probably have a completely different name for them! The sort of thing you would use to tighten the ring on the bottom bracket of a pedal cycle.
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
Old 01-22-2008   #9 (permalink)
neuroboy74's Avatar
my roommate has a yamaha fz6 and has a variety of spanner in his bike's tool kit. that'll be the first try. . . no hurry. given the weather it'll be a while before i get it up to speed (aka, out of the garage)
Rear preload adjustment 86LG4T5 Speed Triple Forum 5 03-01-2007 02:43 PM
Preload adjustment mikey Sprint Forum 7 08-27-2006 06:58 AM
Stock rear shock preload adjustment? rays323929 Twins Talk 2 05-29-2006 10:07 PM
Rear Preload Adjustment, '98 Sprint bajajoaquin T3 Sport / Touring Forum 6 05-13-2005 04:35 PM
spring preload adjustment oldyeller Modifications & Workshop Talk 8 02-06-2005 01:18 AM
