Motorcycle.com
Old 01-18-2008   #1 (permalink)
Front end
I dropped the front front end on the forks to -20mm to match my -20mm Hagon Shocks in there rear.
Is this too much? What is the max you should drop the front end?
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 01-18-2008   #2 (permalink)
MES
Favorite Bike: my next one
MES's Avatar
You have not "dropped" your front end.
what you have done is lowered your bike 20mm. The geometery is the same.
Your OK from a geometery standpoint..
Bonnie 1000th and Sweatmachine correctly point out possable clearence issues.
MES is offline   Reply With Quote
Old 01-18-2008   #3 (permalink)
Bonnie1000th's Avatar
Your OK.
Sorry Clint, but he is not Ok.
He can lower 10 mm safe.
Lowering 20 mm creates a potential risk that under heavy braking the rectifier will hit the fender.
One of my friends had that problem.
Tooo many mods!
1087
T100 Lucifer Orange bonneville.
http://www.triumphrat.net/photogallery/v/member/album788/album1500/aas.jpg.html
Bonnie1000th is offline   Reply With Quote
Old 01-18-2008   #4 (permalink)
Retired Legend
sweatmachine's Avatar
or the horn could hit the fender. I relocated mine under the gas tank for that very reason. I had stock rear shocks and -10mm front. I found that anything over 10mm with stock rear shocks was too low.
alright alright alright
Bonnie cafefighter!
Old 01-18-2008   #5 (permalink)
MES
MES's Avatar
That would be some hard breaking.
No need to be sorry. if your right your right.
And
Your right of course. The rectifier and horn could hit the fender.
(all that matters is that the guy gets the the straight dope)
I was thinking only in terms of the geometery issues. I focused in on that.
Probably because of "dropped" VS "lowered"
Thanks for the save.
The rectifier and horn could be relocated but.
(I went out and took a look.)
The horn in the stock position only sticks out from the cradle by 3/4" or so.
If the horn is an issue, then, could the cradle come into play then?
Old 01-18-2008   #6 (permalink)
Retired Legend
I had a bigger aftermarket horn (Fiamm Roadblaster) and it stuck out farther.
Bonnie cafefighter!
Old 01-18-2008   #7 (permalink)
MES
MES's Avatar
I should have known. Everything is bigger in Texas.
i'm glad you and carlos (bonnie1000th) caught my mistake.
Old 01-19-2008   #8 (permalink)
Sorry I forgot to mention that the horn had already been moved to under the gas tank.
Is it ok if the horn has been relocated?
Old 01-19-2008   #9 (permalink)
bump again
Old 01-19-2008   #10 (permalink)
bump again
Lowering 20 mm creates a potential risk that under heavy braking the rectifier will hit the fender.>>>
I answered your question in my previous post.
If you want to lower the front end more than 10 mm , you will need to relocate the rectifier as well.
Tooo many mods!
1087
01 s3 front end on a 02 s3 Tridolph Speed Triple Forum 6 05-24-2007 12:43 AM
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 04:34 PM
front end johnyramone Speed Triple Forum 0 08-13-2006 03:53 AM
New Front End pbbeck The Rocket Science Forum 4 10-21-2005 08:52 AM
Front end? NickDC Daytona Deliberations 2 06-23-2005 04:21 PM
