Mike,I can only imagine how much your loven those wheels. They got to be great.
Mes, did you change that back tire?
OOhhhhh yeh.
That tire was toast. Good job
I don't think the front is going to last to long either.
I'm doing by best.
My first test ride went well. Understeer lessened. Noticeably quicker turn in, Found myself on the inside of the turn too early a few times. That's a timing issue. Just feeling it out for now.
Re bar swap: "The issue with the Thruxton is not the bars. It is the space. It needs to be a remote fluid container because the of the clip ons,
The brake will hit the guages."
What I meant was that it won't work as a direct swap.
Philmecavity might be on to something though.
