Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShowsMotorcycle.com
Old 01-15-2008   #1 (permalink)
Favorite Bike: 2007 Bonnie Black
Isle de Triumph's Avatar
need advice
Newbie question here: Been thinking about getting K&N filters. Is it possible to install them with the air box still intact? If so, does anyone have pics? Would be very interested in seeing them. Don't think I want to get rid of the box just yet. Also, I believe the bike is running rich??? Cuts out sometimes at red lights. Just shuts off. Like a click...nothing.. Cranks right up...I had the bike rejetted once when I had the AI removed and Emgos installed. Maybe too rich? Please...any advice would be appreciated. Thanks
Isle de Triumph is offline   Reply With Quote
Old 01-15-2008   #2 (permalink)
A K&N filter will fit directly into the airbox as the factory paper filter. What is the present jetting size? How many turns out on your idle mixture? Has the restrictor plate in the airbox been removed?
Jimi_X is offline   Reply With Quote
Old 01-15-2008   #3 (permalink)
Favorite Bike: 06 Bonneville Black
NewOldSkool's Avatar
You could always add a K&N filter or UNI foam one to the airbox (not the pods or cones). Thats what I did and had very good results. But I was getting the same thing where I was going along just fine and at a stop it would want to die... I was running lean though. I ended up going up to a 42 pilot jet and it seems to have cured it. I am wanting to go for a dyno soon, but the white crap all over the place it restricting my passage.
Edit: Oh and I also removed the snorkel and restrictor plate, so that had an effect in the lean conditions for me.
Iraq is stupid!!!
NewOldSkool is offline   Reply With Quote
Old 01-15-2008   #4 (permalink)
Isle de Triumph,
As NewOldSkool said, I'm thinking lean. If you add a K&N in might make it worse. Do you know what size the pilot jet is and how many turns out the mixture screw is?
NewOldSkool, things are pretty white here to. I feel the weight.
Old 01-15-2008   #5 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
are you talking k&n pod filters if so you have to get rid of air box or cut it up.
Old 01-15-2008   #6 (permalink)
Favorite Bike: '06 T100
road_dog's Avatar
Maybe your carbs need to be synchronized? That could also cause the bike to die at red lights. How many miles since the last time that was done?
Phil (road dog)
Click on the Image
for Larger Picture
road_dog is offline   Reply With Quote
Old 01-15-2008   #7 (permalink)
not sure
Not sure what the present jets are or mixture turns. I wasn't told when I picked it up.(forgot to ask)...I might have it on my receipt though.... The bike is a 2007 and 1300 miles so it really hasn't had much work done to it.
Old 01-15-2008   #8 (permalink)
Jimi X...don't believe the restrctor plate has been removed.
I thought the K&N filters were the pod filters...??... see, I'm new to this.. sorry
Old 01-15-2008   #9 (permalink)
mikeinva's Avatar
the good k&n filters are pod filters they make both kinds
Old 01-15-2008   #10 (permalink)
I synced up my carbs right after thinking it might have had something to do with it but no. I even checked the cables after reading that it might be something with that. But that was my case, IdT check your carb balance like RD said. I would see if turning out the A/F screws 1/2 turn helps. If it does, then yes you were lean.
Iraq is stupid!!!
In serious need of advice darcon T3 Sport / Touring Forum 14 05-27-2007 07:14 PM
I need some advice merlotlover Twins Technical Talk 7 04-12-2007 07:12 PM
Any advice? Freakazoid84 Sprint Forum 2 04-30-2006 08:45 AM
Need some advice FDCF1 The Rocket Science Forum 2 08-21-2005 10:42 PM
Need Some Advice muss Twins Talk 6 08-15-2005 10:12 AM
