Be careful
"I do use mostly the front brake. only use the rear to come to a stop once i'm under 10mph".
That sounds really dangerous as well as contraindicitive of everything I was taught. I believe that both brakes should be used for every stop. The front will do a larger percentage to be certain. In a panic situation, a lock up of the front wheel/tire is nearly impossible to recover. That puts you on the ground. I'm sure that a Google search will reveal loads of articels on proper mototcycle barking technique. I am also a huge proponent of the MSF course.
Cheers,
SK
2007 T100 T&O - AI's off, ARK, K&N's, 42 pilots, 140 mains, 2 turns out, D&D silencers, ACR Adjustable Clubman's, KYB's, WP springs, Thrux gel seat______________________________________________
Who's that little old man with Paul?
