Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShowsMotorcycle.com
Old 01-13-2008   #1 (permalink)
Help, Thuxton flasher unit missing!
Hi, I have just bought an 06 Thruxton that has been modified, air box removed, K&N’s etc, and the indicators were also removed. I have bought new set of short led indicators and installed them but they don’t work, I know I might have to buy a solid state relay or fit resistors so looked behind the left side panel for the flasher unit and it doesn’t seem to be there. The last owner had removed the air box and taped up some wires so I started digging and found a square flat plug with a metal clip with 2 wires from it, green&red, Yellow&red, and I can’t find this in my wiring diagram.
The operators manual shows and calls it a flasher relay, but the wiring diagram doesn’t mention flasher relay anywhere, only Direction indicator unit that has 3 wires from it, orange&green, Black, Light green&brown.
Any help would be appreciated.
Ray.
dresda is offline   Reply With Quote
Old 01-14-2008   #2 (permalink)
Favorite Bike: Black 06 Thruxton
Other Motorcycle: Red 01 SV650S
Turn Signal Signal Relay
The Haynes manual has a unit "Turn Signal Relay" that has three wires like the unit you described, "orange&green, Black, Light green&brown". That should be your "flasher" unit.
The only Yellow with Red wires I could locate in the Haynes wiring was for the kill switch and the headlight cutout relay (which I think is housed under the left cover - this relay cuts out the headlight while the starter is engaged). My guess is that the prior owner removed the headlight cutout relay also. My 06 has two relays under the left cover.
Hope this helps.
Tusitala - Mt Vaea
SHILOH is offline   Reply With Quote
Old 01-14-2008   #3 (permalink)
In the original setup, the flasher relay has three terminals that plug into a receptacle which eventually goes back to the wiring harness.
It's been mentioned elsewhere that this flasher is much less expensive if you get one from an auto parts store, compared with Triumph's price. If you want an original type flasher relay, you can search for that thread and save some money and time.
If you want a solid-state flasher to use with LEDs, NewBonneville and other vendors have the self-cancelling item, and I think that NewBonneville also has a plain solid-state flasher, not self-cancelling, which is cheaper. I've never seen the latter on the web site, you might have to e-mail Brent and ask him about it.
Marty
Old 01-14-2008   #4 (permalink)
Thanks very much for your replies. I will get a solid state one but first I have to find the three wires. The problem is, the original harness is black tape and this guy must have tucked in the wires and used more black tape, why?
Ray.
Old 01-14-2008   #5 (permalink)
Flasher
Gotta get a new one- get the self cancelling one!! May save your butt some forgetfull day!!
Got some other cool features on it as well!!
CAPT D
Old 01-14-2008   #6 (permalink)
I will get the self canceling but I am still trying to findthe 3 wires for the flasher, I have checked all through the harness behind the left side panel.
Would like to know what part of the harness they branch out from.
Ray.
Old 01-14-2008   #7 (permalink)
Favorite Bike: the Triumph I'm riding
oldroadie's Avatar
Other Motorcycle: 04 America
Extra Motorcycle: 01 Bonneville
I'd have to look at my bike to be certain but I think this airbox mod picture show the relays still mounted on the airbox (what's left of it) to the rear of the starter solenoid. Unless the former owner really cut them back the leads you're looking for ought to be close to this region.
2001 Bonneville
2004 Bonneville America
oldroadie is offline   Reply With Quote
Old 01-14-2008   #8 (permalink)
Thanks, great picture, the flasher is on the left, now if I could only follow those 3 wires. If I could figure out how to post a picture I would show you my rats nest.
Ray.
LED Indicators / Flasher Unit Blackjack Twins Technical Talk 1 03-12-2007 09:16 AM
Flasher unit JontyG Speed Triple Forum 3 02-26-2007 01:11 PM
'98 T595 flasher unit Shark Daytona Deliberations 3 12-17-2006 06:13 PM
Newspeed flasher unit Spendthrift Speed Triple Forum 14 11-30-2006 04:30 PM
Flasher Relay Unit GrahamC Speed Triple Forum 7 06-12-2006 09:55 AM
