AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
ShopTriumph.com
Old 01-08-2008   #1 (permalink)
Thruxton Footpeg Relocation...
Gents,
Aside from the option of retrofitting Bonnie mid set foot controls on a Thruxton, is there an aftermarket alternative that moves Thruxton foot controls a bit more forward and lower?
Many Thanks,
George
biker7 is offline   Reply With Quote
Old 01-08-2008   #2 (permalink)
Favorite Bike: '05 Bonne 790
Lockhart Phillips Foot pegs - LP Super Pole V-360 Knurled Foot Pegs
something like these, maybe?
http://www.indysuperbikes.com/Isb1/l..._footpegs.html
Roca790 is offline   Reply With Quote
Old 01-08-2008   #3 (permalink)
BellaCorse's Avatar
To make the swap with OE parts you need the frame outriggers, brake pedal, master cylinder, hose, shift lever and pegs. I'm not sure about the Thruxton RH side cover... it may need to be notched at the bottom for the brake rod.
I want to swap my T100 foot controls for Thruxton parts. Anyone interested?
/Mike
BellaCorse is offline   Reply With Quote
Old 01-08-2008   #4 (permalink)
Favorite Bike: 06 Bonneville Black
NewOldSkool's Avatar
Mike,
I swaped out my standard Bonnie foot controls for a set of Thruxton rearsets. I love it, but you will have some issues with the stock Bonnie exhaust pipes if you have them. The Thrux ones seem to be about an inch or two longer before the bend, and with the bend closer on the stock Bonnie pipes you will not be able to lower the gear shifter all the way without hitting the pipes. It will be just slightly higher then want I consider best placement for the shifter. Aside from the parts you listed already, you will also need the switch and mounting bracket for the rear brake light too. But really a easy job.
Iraq is stupid!!!
NewOldSkool is offline   Reply With Quote
Footpeg woes dunringil Hinckley Classic Triples 7 10-16-2007 10:23 AM
footpeg crisis metasac Twins Technical Talk 19 09-05-2007 06:51 PM
Thruxton footpeg conversion to bonneville pegs? Scottius Twins Technical Talk 6 04-10-2007 07:44 PM
rider footpeg mosby Daytona Deliberations 3 03-09-2007 11:41 PM
Thruxton/Bonneville footpeg trade? markbvt Club Cafe 1 01-20-2006 09:31 AM
