If you run it on 3 parts Premium and 1 part Swan Lager the noise goes away.
Its only cause the standard intake and exhuast is so muffled that you can hear those noises.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
