Hello folks,
Hope you've all been having a good time at Christmas.
I was looking at the front axle bollt, and noticed that there seems to be a bit more space than usual between the spacer on the left and the inner side of the fork. Everything seems to be at the correct torque.
I'm hoping you can go take a look at yours, and maybe post a pic of what it looks like? I may be chasing ghosts here, but I wanted to ask anyway.
Also, while we're on the topic of axles:
1) There's not much free thread left on the front, after tightening the nut... is this a worry?
2) Neither front nor rear axle nuts have any sort of safety pin (not sure of the technical term), to ensure that the nut does not come loose, like I've seen in other bikes - any comments about this.
3) There's a plastic tube/end cap thing that goes through the axles. Does this serve any purpose? The right hand (speedo drive) side end cap on the front is broken off.
Pics are standing in front of the bike, and looking towards the back. Sorry the bike ain't all that clean... I took the pics as soon as I got back. About 40000kms now, and doing pretty well... certainly plenty of thanks to all you fine folk here!
1) Front axle - left side close up with the axle pinch bolt: you can see there's a little bit of space (like and intented lip) between the inner edge of the fork and the outer edge of the spacer
2) Front axle - left side wider view
3) Front axle - right (speedo drive) side close up: aint too much free thread at the end of the axle. You can also see that the plastic end is broken
4) Front axle - right side wider view
5) Xmas evening ride - was a little bit rainy
http://i58.photobucket.com/albums/g2...e/14da3131.jpg
