Old 12-26-2007   #1 (permalink)
Retired Legend
sweatmachine's Avatar
problem with motorcycle jack
It seems that the actual jack part of my Sears Motorcycle jack has failed. I can pump/lift it up but the pressure only builds at the very bottom of the motion. It was an overnight thing, and I hadn't done anything to the jack itself.
Anyone ever have one of these fail? Seems like a simple bottle jack. I called Sears and of course got 2 idiots, one informed me "they don't sell motorcycle parts" and the manager informed me "I don't know that much about tools." I kind of feel like Hank Hill buying plumbing elbows at the Megalow Mart...
Old 12-26-2007   #2 (permalink)
Sweat,
Maybe try the info in this thread so you can just order the jack or part of the jack.
http://forum.doityourself.com/showthread.php?t=123575
ATGATT is offline   Reply With Quote
Old 12-26-2007   #3 (permalink)
Favorite Bike: the Triumph I'm riding
oldroadie's Avatar
Other Motorcycle: 04 America
Extra Motorcycle: 01 Bonneville
I wonder if maybe, like my Jet brand left, it's been leaking a bit of hydraulic fluid? Bottle jack hydraulic fluid is available at the local auto parts store, it's very common. First, you pull the rubber bung in the side, then turn it upside down and fill til it's level with the opening. Back upright, give it twenty pumps or so to purge the air and refit the bung. Good to go.
2001 Bonneville
2004 Bonneville America
oldroadie is offline   Reply With Quote
Old 12-26-2007   #4 (permalink)
Favorite Bike: 2004 Thruxton
Other Motorcycle: 1997 Thunderbird
Extra Motorcycle: 1973 Norton
bike jack
Check the oil level in the bottle jack,it sounds like it's low. you can use standard hydraulic oil or ATF trans fluid. There should be a rubber plug in the side of the bottle jack for filling. I hope this helps.
TTRIDER is offline   Reply With Quote
Old 12-26-2007   #5 (permalink)
Favorite Bike: 2007 Bonneville Black
I had the exact same problem with a Sears bike jack after only about a year of very occasional use. It probably had weight on it fewer than 20 times. Finally gave it away since I could not trust it. Rubbish.
smartin108 is offline   Reply With Quote
Old 12-26-2007   #6 (permalink)
Retired Legend
I love this forum!
thanks guys, lots of good info here. Wish the folks at Sears were as helpful!
Old 12-26-2007   #7 (permalink)
MES
Favorite Bike: my next one
MES's Avatar
As said above, the fluid level is low.
Use ATF you you should be good to go
MES is offline   Reply With Quote
Old 12-26-2007   #8 (permalink)
Favorite Bike: Bonneville
And just when you thought that nobody knew Jack.
2005 Bonnie, TORs and Unifilter, AI gone, Modre's peg kit, headlight & brake modulator, tach, bright leds, NC wind deflector, gaiters, steibel, vmax mirrors, dresser bars, Hagons & Progressives. http://TexasCoastGeology.com
geolpilot is offline   Reply With Quote
Old 12-26-2007   #9 (permalink)
idaho_thrux's Avatar
First two places that I would check would be the seal, and then many of them have a type of bleed off valve that when open won't let any hydraulic pressure build.
My Blog--BritBikeBlog.com
"Beer is God's way of telling us he loves us, and wants us to be happy." -Ben Franklin
"Few men think; yet all have opinions. Hence men's opinions are superficial and confused." -George Berkeley
idaho_thrux is offline   Reply With Quote
Old 12-27-2007   #10 (permalink)
bendavanza's Avatar
Never trust your bike on the hydraulic lift alone, use the locking thing to secure it.
Yeah your fuid level is probably low. If it's hosed beyond that and you can't find a seal, it's just a bottle jack you can find at auto parts/ harbor freight etc.
-Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Motorcycle jack retrobiker Classic, Vintage & Veteran 4 11-05-2007 07:02 AM
Motorcycle Jack for TBird? Beemie Hinckley Classic Triples 7 09-12-2007 11:42 AM
Motorcycle Lift (Jack) bruin Twins Technical Talk 9 06-29-2006 09:08 PM
Motorcycle jack triumphrider99 Hinckley Classic Triples 8 12-15-2005 03:19 PM
motorcycle jack/lift RandyDTFR Twins Talk 20 10-11-2005 08:20 PM
