Theoretically, if the gasket is dry and clean, and all mating surfaces are also, the gasket should be fine. In practice, it seems about half the folks have a bit of a leak from the cam cover and half dont.
If RTV or silicone sealer is used, go sparingly, you dont want to get any excess inside the cover.
I use 3M gasket/ trim adhesive, AKA gorilla snot, to do this job.
It goes in a very thin bead, seals great.
G
I just wanted to ride
