BikeBandit
Old 12-25-2007   #1 (permalink)
Throttle spring tension
Is there a way to adjust the spring tension to add more resistance in the throttle grip? Or, other methods.
Om mani padme hum doo lang doo lang shooby dooby Karma down dooby down. Let us dance to the music of compassion.
Flyingscott is offline   Reply With Quote
Old 12-25-2007   #2 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
I'm sure there's a return spring that can be replaced with a heavier one. Why would you want to do that? Typically (at least with me) I do all I can to arrive at the lightest throttle resistance, as long as the spring can return the throttle to idle. I just found springs for my old Beemer that provide a much lighter throttle input.
Bob
Old 12-25-2007   #3 (permalink)
That's the problem
It does not return to what ought to be the idle position even though it is at idle. Still about an 1/8 turn slack.
Old 12-25-2007   #4 (permalink)
OD6
I would not change the spring tension, if the reason you want to
change the tension is of hand fatigue. The Bike shops sell a
part that fits on the trottle so the heal of the hand turns and
holds the trottle in position rather then your hand grip.
OD6 is offline   Reply With Quote
Old 12-26-2007   #5 (permalink)
these have plenty of spring resistance. I think your issue is of the cable hanging up -very not good, get it taken care of- or the throttle cable tension needs to be adjusted. Is there slack where the throttle has no effect, or no slack, where the cable is adjusted too short and keeps throtle open?
G
I just wanted to ride
Old 12-26-2007   #6 (permalink)
Favorite Bike: 2001 Sky Blue Bonneville
Have you tried adjusting the cables? to take up the slack
Ian
Skyblue62 is offline   Reply With Quote
Old 12-26-2007   #7 (permalink)
ohiorider's Avatar
The thought just hit me ..... on our Triumphs, one throttle cable is used to open the carbs, the other is used to pull them closed. It would seem that if the cables are adjusted properly, you should be able to return the throttle to idle by physically twisting it to the idle stop. If you can do that and she idles down, but the throttle hangs up when you rev it slightly and let go of it, then it sounds like one or both cables are bent too tightly, damaged (kinked), or perhaps the cables are starting to wear out. When cable strands start to break, they can hang up inside the outer cable sheath.
Bob
Chain tension superfour Tiger Mods & Bolt-Ons 4 02-02-2008 06:03 PM
99 TBS Throttle spring Alpha Hinckley Classic Triples 15 08-29-2007 12:06 AM
Chain Tension TOMKRILL Twins Technical Talk 12 05-16-2007 06:14 PM
throttle return spring, hard suspension jbirdfl Sprint Forum 10 08-26-2006 09:44 PM
CHAIN TENSION henders Hinckley Classic Triples 7 07-02-2005 04:45 AM
