Old 12-23-2007   #1 (permalink)
Favorite Bike: 1973 Benelli Bashee
Other Motorcycle: 2004 Black Bonne
running on one cylinder
hey.....started her up after only being down for a month and she's only firing on one cylinder. Every once in a while the left (as I sit) will catch then die out again. it doesn't sound serious, but any quick fix ideas before I start to lose hair over it? Tanks full, but it has been cold as hell around here and it's a really really wet day but warmer..
DC
bonnecom is offline   Reply With Quote
Old 12-23-2007   #2 (permalink)
Favorite Bike: My Bonnie!
coelacanth's Avatar
spark plug? clogged left carb?
07 Bonnie
Black/red T-100 tank with black headlight shell, rear fender eliminated, short front fender, Monza Cap etc.
AI/snorkel removed, UNI filter with TORs. 120 / 40 jets, 1 shim, 2.75 out. EBC HH brake pads.
coelacanth is online now   Reply With Quote
Old 12-23-2007   #3 (permalink)
bendavanza's Avatar
2 quick things
1 drain the carbs, there is a small drain screw on each carb, et the bottom of the bowl facing you. Drain enough gas to have done some rinsing, at least a cup or 2 per carb, esp the problem side.
2 check the plugs. You will need an 18mm spark plug socket, Sears has a nice one or you can look around but they are not very common sockets. you could also grind down the outside of a 18mm deep well socket.
-Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 12-23-2007   #4 (permalink)
Extra Motorcycle: '99 SV650 (for sale!)
Had this problem with my '04, running intermittently on one cylinder while the choke was engaged. Turned out to be a clogged enrichening circuit. Pulled the carbs and gave 'em a good going over with spray-type carb cleaner, end of problem!
Bill
\"A motorcycle is a tool, not a fashion accessory"
My Bobber
bmetz99 is offline   Reply With Quote
Old 12-23-2007   #5 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
+1 bmetz99,
Had the same problem.Had to take the petcock off and clean the filter it was also clogged by the tank liner paint they use breaking down.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 12-23-2007   #6 (permalink)
Favorite Bike: The one I'm riding now.
gonzo'st100's Avatar
Other Motorcycle: Vespa 150 Scooter
I had a clogged jet on mine. My right cylinder would fire only upon putting a load on the engine.
gonzo'st100 is offline   Reply With Quote
Old 12-23-2007   #7 (permalink)
Another possibility
If all that does not help then it is a blown diaphragm in the air injection valve which is causing that cylinder to go lean....
Pull off the vacuum hose on the left carb spigot close to the head and suck on it ,,,, if you can pull a vacuum then the valve is aok, but if air comes through then the diaphragm is shot....
Cold weather and ethanol in the gas make for rubber parts that are prone to splitting....
Good luck with it !
Robert
If we arn\'t having fun,,,then we arn\'t doing it right.....
Motorboy is offline   Reply With Quote
Old 12-23-2007   #8 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
always start with the simlest thing first it can be many things as the guys have said ,but dont go through all the other stuff until you have cahnged your plugs then work back from there.
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 12-28-2007   #9 (permalink)
Thanks all..I'll let you know how it turns out.
Old 12-28-2007   #10 (permalink)
Favorite Bike: 2007 Bonneville Black also 1949 Panhead Harley (Past)
Switch the plugs you have if opposite cylinder misfires, it's the plug. Just a quick check.
2wheeltherapy is offline   Reply With Quote
1st Post: Running on one cylinder and Cleaning fingerprints off of blued headers??? scooter1942 Twins Technical Talk 5 09-25-2007 04:35 PM
Running on one cylinder... GrayMitchell Classic, Vintage & Veteran 2 09-09-2007 04:44 AM
Running On 1 Cylinder: Brilliant Diagnosis! mistermellow001 Twins Technical Talk 16 08-19-2007 10:32 AM
Running on one cylinder kcnlisa Twins Technical Talk 10 08-21-2006 11:37 AM
Bonnie running on one cylinder Eric3742 Modifications & Workshop Talk 10 11-17-2004 09:53 AM
