» Links |
12-23-2007
Formula Extreme Favorite Bike: Bonneville 07, "Bonnie"
Posts: 456 Other Motorcycle: Past rides, 66 bonneville Extra Motorcycle: Past rides, 72 bonneville
shifting speeds
Here's an interesting one.....
Can anyone tell me where the shift points (ie redline) would be on the speedometer?
Since I won't likely get a tach conversion kit for a while, what I'd like to do is to mark on the speedo with a little dot of white-out, just where, or at what mph i should be shifting up to each gear from first to fifth......ie/ 40 mph in first, 65mph in second...etc etc....
I've been looking everywhere for that info, found some on the 02 bonnies but nothing yet on the 07 which i have.
Any help or suggestions would be greatfully appreciated....
Thanks...
bill
Mods: snorkel removed, bafflectomy, jets out 3 turns, summer screen, cortec tank/saddlebags, Bella Corse Highlander bars,Modre peg lowering kit,Drag specialties mini tach, D9 bracket.
SuperStock Favorite Bike: 1968 bonneville
Posts: 219 Other Motorcycle: 2007 blk/wht bonneville
I rarely use my tach. I hear the pipes and just feel for it.
I have only been drunk twice...the 60s & 70s
2007 T100,Blk/Wht,Ai removed,D&Ds,Snorkel out,restrictor plate out/one shim/ 132mains/40 pilots/3 turns
12-23-2007
Team Owner Favorite Bike: 2003 T100
Posts: 3,702 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: No more at present time
If you have the 2002 data, this may help.
As far as I know, the only difference in stock 2002 and 2007 drive ratios is in the final drive, with an 18 tooth countershaft sprocket vs a 17 tooth. I believe the primary and 1 thru 5 gear ratios are the same.
I think this math works:
2002 final drive: 2.53:1
2007 final drive: 2.38:1
2.53/2.38 = 1.06 or approx 6 % difference.
In other words, the 2002 will be revving approx 6% higher at the same road speed with stock gearing.
Not sure if you'd need to run this for every gear ratio, or if this covers it for all ratios. Think it does.
Bob
12-23-2007
Aproximate redline (7000rpm)
I tested this on my 2006 Bonnie that has TORs, rejet, and K&N, no snorkel. I tried to keep track of what speed I shifted when the tach hit 7000 rpms:
1st - 50
2nd -70
3rd - 85
4th - 95
That is what my speedometer showed but it is about 5mph optimistic, so actual speed would be about 5mph less than what I listed. Also, I didn't bounce the rev limiter so pushing it as far as you could go would result in slightly higher speeds.
'06 Bonnie Black - AI and snorkel removed, TORs, K&N, IKON rear shocks, Hagon fork springs, Pingel, Tach added, K&Q seat, centerstand, Lucas Style Sport lights
12-23-2007
Speed in Gears
Sponger has it rite on cept for me its 2 mph less till it hits the limiter.
CAPT D
12-24-2007
1st - 50
2nd -70
3rd - 85
4th - 95
You are shifting at 7K? On what model 865 or 790c? Was this just a test?
I shift at about 4500 - 5000 RPM on an 865 Bonnnie.
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
12-24-2007
Moto Grand Prix Favorite Bike: Definitely my 2007 Black
You shift around 4500-5000 RPMs? Hell son, your missing an awful lot of fun!
12-24-2007
I don't shift at 7K usually, only ocassionally when I jump on it. I usually don't go past 5K or so during normal riding...
12-25-2007
SuperBike Favorite Bike: 03 T100 989
You got that right 5000 to 8000 is where the fun is.Love the feeling shifting into 4th at 95 mph thats when she is moveing.
