Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
BikeBandit
Old 12-23-2007   #1 (permalink)
Favorite Bike: 07 Silver Bonneville
BonneRider's Avatar
Jenks Bolts Tuning Notes Question
I have silencers made by TJ Wassell. You can see straight thru them, no baffles. I would consider them to be "Open" exhaust. Am I correct? The notes have 3 types of exhaust, Triumph "Off Road", "Off Road", and "Open".
07 Silver Bonneville.......Triumph Gaitors, M-Bars, Lucas Taillight, Small Bullit Marker Lights, TJ Wassell Silencers, Tank Pads
BonneRider is offline   Reply With Quote
Old 12-23-2007   #2 (permalink)
Yes, tho the TORS can be seen thru as well. They are just a little more restrictive than most after-market pipes.
BUT- there are different levels of open, as well. A really wide open one, such as BUBs and D&D, run better when the pilot jet is bumped to a 42, and a main of perhaps 150.
Some slightly less radical ones, Sprints, Teardrops, Preds, and a host of others run best on a stock 40 pilot and about 140 main. Both set-ups usually improve with a shim on the needle. Adyno is nice to get it spot on, but you can do it thru plug watching and how it runs, if you have experience at it. My dyno run told me to change nothing, as I somehow nailed perfect by trial and error. Have fun, and good luck!
G
I just wanted to ride
Old 12-23-2007   #3 (permalink)
Originally Posted by Geoff View Post
Some slightly less radical ones, Sprints, Teardrops, Preds, and a host of others run best on a stock 40 pilot and about 140 main!
G
140 mains on 865? With or without an airbox?
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 12-23-2007   #4 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
that would be with NO airbox
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 12-23-2007   #5 (permalink)
Favorite Bike: The one I'm riding now.
gonzo'st100's Avatar
Other Motorcycle: Vespa 150 Scooter
BoneRider,
I have similar pipes (Commando Specialties). Just came back from a 200-mile ride today and my bike ran flawlessly.
-42 jet
-118 main jet
-One shim under each needle.
(modified box, AI removed and K&N)
The sound at high RPM's is awesome!
gonzo'st100 is offline   Reply With Quote
Jenks carb tuning specs with predators NESS Twins Technical Talk 1 02-03-2007 10:46 AM
Jenks carb tuning specs with predators NESS Twins Technical Talk 4 02-02-2007 08:20 PM
Tuning Notes webonnielad Twins Technical Talk 0 01-22-2007 03:24 PM
Jenks Bolts Dickie2679 Twins Talk 2 11-20-2006 09:14 PM
Tuning notes for Hinkley Bonnies and Thruxtons Doctor Club Cafe 5 12-19-2005 04:27 PM
