Old 12-22-2007   #1 (permalink)
Newbie
Jets again
I have a 2005 T100 865,AI removed .snorkel removed,unifilter fitted,125 main jet,40 air jet,2.5 turns out,free flow silencer fitted,restrictor still fitted.BUT IT STILL RUNS TO RICH.can anyone help??????
MOZZA12 is offline   Reply With Quote
Old 12-22-2007   #2 (permalink)
Sweatmachine would suggest that you run a search, he doesn't like answering the same question twice.
I can't answer your question, but I like reading answers more than once, because it often doesn't sink in the first time, or I forget.
Good luck to you!
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 12-22-2007   #3 (permalink)
Favorite Bike: '01 Bionic Bonnie
ggRAT's Avatar
Here are the some of the settings of our members...
(There is no SINGLE right answer for YOUR bike. But I hope this helps.)
STOCK/BASELINE FOR BONNEVILLES & THRUXTONS (Unverified)
790cc w/Keihin CVK36 with Air Box (+) and Air Injection (+)
MAINS /PILOTS/TURNS/NEEDL/SHM/AB/AI/EXHAUST
110.0 / 40.0 / ... /Stock/ . /+ /+ /Stock (Bonneville & T100)
110.0 / 40.0 / ... /Thrux/ . /+ /+ /Stock (Thruxton)
MODIFIED BONNEVILLES & THRUXTONS
MAINS /PILOTS/TURNS/NEEDL/SHM/AB/AI/EXHAUST.....RIDER
125.0 / 40.0 / ... /stock/ . /no/no/Emgo........oldroadie
122.0 / 42.0 / ... /stock/ . /+ /no/TORs........ohiorider
125.0 / 42.0 /-2.5 /stock/ 1 /+ /no/Emgo........NewOldSkool
158.0 / 42.0 /-1.0 /stock/ 0 /- /. /NH Togas....RedBird
145.0 / 42.0 / ... /Thrux/ . /no/no/? ..........Loxpump
130.0 / 42.0 /-2.5 / ... / . /no/no/Staintune...pabonne
125.0 / 40.0 /-3.0 /Thrux/ 1 /. /no/NH Togas....webonnielad
125.0 / 42.0 /-2.25/stock/ 0 /no/no/Thruxton....jcline8
790cc w/Mikuni42
152.5 / 22.5 /-.50 / ...........................bonnieblackinfl
865cc w/Keihin CVK36
140.0 / 42.0 /-2.5 /Thrux/ 1 /no/no/Dominator...SLOBonnie
142.0 / 45.0 /-2.5 /stock
/ . /../../Predators...Chalawah
132.0 / 42.0 / ... /stock/ 1 /no/no/EMGO+DW.....TridentDave (DW=Dunstall Widemouth)
125.0 / 45.0 /-1.75/Thrux/ 0 /no/no/D&D.........GREYTOP
140.0 / 42.0 /-2.0 /stock/ . /no/no/D&D.........Kramocker
130.0 / 40.0 /-3.0 /Thrux/ 1 /no/. /Epco........05Truxter
125.0 / 42.0 /-3.5 /stock/ 1 /no/no/TORs........BlueJ
125.0 / 40.0 /-2.5 /stock/ 1 /no/no/TORs........gumpT100
140.0 / 42.0 /-3.0 /Thrux/ 1 /. /no/D&D.........Thruxtonone
142.0 / 40.0 /-3.0 /...../ 1 /no/no/Predators...Thrux-ton-up
142.0 / 40.0 /-3.0 /stock/ 1 /no/no/MototwinSS..Wolverine
865cc w/Keihin CR
125.0 / .... /-2.0 /Thrux/ . /no/no/Predators...SHRuuM
120.0 / 60.0 /-2.0 /...../ . /no/no/Raask.......Blackjack
904cc w/Keihin CVK36
140.0 / 45.0 /-1.5 /Thrux/ 0 /no/no/Predators...ggRAT
152.0 / 45.0 /...../...../ . /../../............Brooksie
155.0 / 40.0 /-4.5 /...../ . /../../............jojje
140.0 / 42.0 /...../...../ . /../../............ttbonnie
155.0 / 42.0 /-1.0 /...../ . /../../............sweatmachine
150.0 / 42.0 /...../Thrux/ . /../../Bubs........vertwrks
904cc w/Keihin FCR39
150.0 /....../...../...../ . /no/no/............robnobrakes
904cc w/Mikuni42
142.5 / 22.5 /-.75 /...../ . /no/no/............SCCTrim
1200cc w/Mikuni42
147.5 / 22.5 /-.50 /...../ . /no/no/............bonnieblackinfl
NOTE1: For Speedmaster & TBA settings go to Pat's Triumph Site
http://www.dinqua.com/Triumph/carbs0.html
NOTE2: For more info, see old thread...
http://www.triumphrat.net/club-cafe/...-database.html
or
http://www.triumphrat.net/club-cafe/...ot-jets-3.html
NOTE3: Elevation is < 1000 ft. above sea level unless noted.
GO:904cc/-AB/-AI/K&N/Jets:140,45,-1.5,3mm/Predators/ceramic headers/180 rear/Ohlins/Works/520+19Tx43T
SHOW:Pazzo levers/Gaiters/Oberon pegs/new lights/SS braided cables/68 flyscreen,seat & cowl Old & New Pics
ggRAT is offline   Reply With Quote
Old 12-22-2007   #4 (permalink)
Favorite Bike: '07 Bonnie Black
stoatgrinder's Avatar
Right now I have the same setup on my '07, and yes, it is running rich as well. Just did a dyno run that proved it. I was somewhat surprised because the plugs didn't look too bad. Still, I knew the bike wasn't running clean at full throttle and my mileage was terrible. For our bikes the 125 mains appear to be too rich without removing the restrictor plate in the airbox. I just ordered 122's as well as a Jenk's velocity stack for the airbox opening. I'm thinking that will do it for now.
'07 Bonnie Black
stoatgrinder is offline   Reply With Quote
Old 12-22-2007   #5 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
i'd suggest 120 main would be closer to the mark
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 12-22-2007   #6 (permalink)
Favorite Bike: My Bonnie!
coelacanth's Avatar
I second 120 mains.
I have close setup for my 07 bonnie. My cans are TORs though.
I was playing with 120 / 125 mains, with / without snorkel. Both 120 with snorkel and 125 without snorkel turned out a bit too rich. I'm trying out 120 without snorkel and feeling pretty good.
07 Bonnie "The Orange One"
Orange/black tank with black headlight shell, rear fender eliminated, short front fender, etc.
AI/snorkel removed, UNI filter with TORs. 120 / 40 jets, 1 shim, 2.5 out.
coelacanth is offline   Reply With Quote
Old 12-22-2007   #7 (permalink)
Originally Posted by coelacanth View Post
I second 120 mains.
Yeah that sounds correct, but if you have Togas or Sprints you need 125's.
I ran with 120's with Sprints and the bike ran like crap.
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 12-22-2007   #8 (permalink)
coelacanth's Avatar
Right. MOZZA, what cans exactly do you have? I can imagine the level of free-flow-ness is TORs < Dominators Touring < Sprints.
stoatgrinder feels 122 is good for Dom Touring, which I suppose a little less open compare to true free flow cans. If your cans are truly free-flow like EMGO/Sprint or Togas, 125 should be about right.
I actually fitted 125s with Sprints after talking with JKDJose and felt that was right on. I switched to TORs shortly after so I couldn't really spend enough time with the setup though.
Main Jets & Pilot Jets ggRAT Club Cafe 21 11-13-2007 08:52 AM
Which way up for jets? UK Davesky Twins Technical Talk 13 08-20-2007 08:19 PM
Dynojet Jets vs. Misc Mikuni Jets ResearchRat T3 Sport / Touring Forum 21 04-05-2007 06:17 PM
Jets Loxpump Twins Talk 1 04-10-2006 07:58 PM
Jets kan4132 Twins Talk 8 10-01-2005 08:46 AM
