nissin radial master cylinder - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-18-2007, 03:12 AM   #1 (permalink)
Favourite Bike: Triumph Thruxton
vanson1200r's Avatar
Other Motorcycle: Kawasaki ZRX1200R
I picked up a nissin radial master cylinder for the Thruxton but upon installation...............well it just will not fit. I was made for a Suzuki GSX-R 1000. I was looking for a little stronger braking but alas it was not to be. The throttle cables would not clear and I would of had to grind some material off the handle bar in order for it to fit. But on a good note I received my AI deletion kit from Bella Corsa and it was a breeze to install. I could not believe the pile of parts that came off!
vanson1200r:2007 Thruxton Red with white stripe. AI, Emgo's, 125's, Shim's, Polaris Bellmouth, K&N.
vanson1200r is offline   Reply With Quote
Old 12-18-2007, 04:26 AM   #2 (permalink)
Favourite Bike: Bonnie
BrianM's Avatar
Other Motorcycle: Moto Guzzi V11 Sport
Extra Motorcycle: Wife's '68 Bonnie
I've been thinking about how I can improve the front brake on my Scrambler. It's really quite poor.
Any thoughts out there?
BrianM is offline   Reply With Quote
Old 12-18-2007, 05:39 AM   #3 (permalink)
Favourite Bike: Bonneville 2005
chedd's Avatar
Other Motorcycle: Suzuki Dr250
I replaced my disk with one from 'metal gear' and fitted a braided metal brake line and sintered metal pads. This improved the brakes substantially, still not a match for a good twin disk set up but much better than stock.
2005 Bonnie, grab rail, centre stand,taco, ikons, new front springs, bafflectomy.Metal gear front disk & braded line,K&N,no snork,115s,stock needle.
chedd is offline   Reply With Quote
Old 12-18-2007, 12:52 PM   #4 (permalink)
Favourite Bike: 05 T100
I've fitted EBC HH pads, an EBC floating disc and a Goodridge stainless line (the stock is SS by the way, but disguised by a black plastic wrap) to the front end of my T100 and they were all an improvement. But, the only thing that really gave me what I was looking for was a Beringer four piston caliper. They're nicely made bits of kit but cost £250 in the UK. All in all, I think they're worth the cash if you're used to something like a Ducati with a pair of four piston Brembos up front and find the Bonneville front brake a bit weak. By the way, most people who've tried both, think the larger floating disc and different master cylinder of the Thruxton make it's front brake feel better than that of the Standard and T100. I don't know about the Scrambler as it seems to be a hybrid with the Standard's smaller (non-floating) disc and the Thrux's master cylinder.
Paul.
Herts. UK
Old 12-18-2007, 01:11 PM   #5 (permalink)
Favourite Bike: 2006 Thruxton 904
robnobrakes's Avatar
Other Motorcycle: 1994 Ducati 900SS
Extra Motorcycle: 1998 Tiger 885
6-pot Billet Alloy
http://www.pretech.co.uk/consumer/in...xt=engineering
Enough said!!!!!
Rob
Thruxton 904 :::: BritishMotorcycleGear.com Bike of the Year 2010 - 2011 ::::
Gallery http://www.triumphrat.net/memberalbu...ry.php/cat/524
robnobrakes is offline   Reply With Quote
Old 12-18-2007, 04:26 PM   #6 (permalink)
MES
Favourite Bike: my next one
MES's Avatar
Ron,
what is the pad set up like on the pretecks? are they like most 6 pot in that they have 6pads?
How much for the unit? Pad types?
For those looking to improve braking but don't want to pony up for high $ brakes
You can use a Rocket3 master cyclinder (both are 1" bars). It's a direct swap $240.
14mm instead on 10mm.
MES is offline   Reply With Quote
Old 12-18-2007, 04:37 PM   #7 (permalink)
Originally Posted by MES View Post
Ron,
Cost £280.00 (including UK Value Added Tax)for the caliper, stainless steel brake line, stainless steel bango's and EBH HH sintered pads.
Two pads fitted, not 6.
Rob
Old 12-18-2007, 05:02 PM   #8 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
How does a different master cylinder improve braking?
Marty
Old 12-18-2007, 05:38 PM   #9 (permalink)
I'm no expert but radial mounted master cylinder offers less flex and better feel and leverage. Also depends on the piston size and is must match your brake caliper. I had the nissin mounted on my ZRX1200R with twin six pot calipers and steel lines but the piston in the master cylinder was set up for a bike with 4 piston calipers. I took the radial mount off and the stock lever feels better with the steel lines on the ZRX. I tried to mount it on the Thruxton because due to the better leverage I was hoping to get stronger braking (I have a bad habit of using only two fingers) but it would not fit. Back to stock on both bikes and an unused nissin radial master cylinder on my bench.
Old 12-18-2007, 06:23 PM   #10 (permalink)
Favourite Bike: 06 Yellow Thruxton
rbrian_taylor's Avatar
vanson, any pics that you want to share to see if "we" can figure out a way to make it work? I am very interested in this endeavor.
rbrian_taylor is offline   Reply With Quote
Brembo Radial Master Cylinder Fitted robnobrakes Twins Technical Talk 9 03-19-2008 10:18 AM
Radial Master Cylinder chukus13 Speed Triple Forum 2 06-05-2007 02:21 PM
Selling my 675 stock radial master if interested. brettmess24 Speed Triple Forum 8 10-17-2006 10:13 PM
Anyone mount a Brembo Radial Brake master to 05+ S3 brettmess24 Speed Triple Forum 49 06-13-2006 09:10 PM
Brembo Radial Master installed! Yeehaa brettmess24 Speed Triple Forum 12 06-11-2006 10:41 AM
