Bad engineering practice - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-17-2007, 10:53 PM   #1 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
just reading the snorkel removal thread ,and it is in my opinion not only bad practice, but completely unecessary to have a great oval hole open to the elements in your airbox. imagine if that was your car running that set up bad idea ,what i did was modify the snorkel to flow more air and protect my airbox from water intruision,and it does happen no mater what you read here,I road tested the bike and its probably my imagination havent done enough miles yet, but the mid range feels stronger and its staying in ! comments .
stock snorkel
modified snorkel
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 12-17-2007, 11:01 PM   #2 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
I say ditch the whole affair for individual air filters. Why waste time with the airbox and snorkel when it has been proven that the individual filters make more power with no downside?
Old 12-17-2007, 11:35 PM   #3 (permalink)
RonD's Avatar
your correct, but iam happy with the bike at the moment, but iam never happy for to long when it comes to playing with bikes, so dont tempt me iam weak and i might do it..as a matter of fact i like the way i think rev has his set up, it looks well engineered hmmm.
Regards Ron
Old 12-17-2007, 11:37 PM   #4 (permalink)
Favourite Bike: 01 Bonneville
Ron,
Thanks for the insight and photos. Let us know how the road testing goes.
Mike
DBMike is offline   Reply With Quote
Old 12-17-2007, 11:44 PM   #5 (permalink)
RonD's Avatar
ok mike will do .
Regards Ron
Old 12-18-2007, 12:07 AM   #6 (permalink)
Favourite Bike: 69 Tiger TR6R
pabonne's Avatar
Other Motorcycle: 2003 Bonneville
I did the snorkel trim thing at first too. Bike went from lean to super lean and felt like she only wanted to rev to the moon, nothing at the bottom or mid whatsoever. Tried to rejet, broke my carbs, got a new set, rejetted and did the KARK.
2003 790 Bonne (black, not Black) / 1969 Tiger TR6R (oh so sweet)
Addicted to Triumphs for over 40 years.
pabonne is offline   Reply With Quote
Old 12-18-2007, 12:26 AM   #7 (permalink)
Favourite Bike: Triumph Thruxton
vanson1200r's Avatar
Other Motorcycle: Kawasaki ZRX1200R
Pabonne,
Broke your carbs? What happend? I just received my Polaris bellmouth but I am waiting to install it till after I get my pipes and re-jet. Did your re-jetting go bad? What should I avoid?
vanson1200r:2007 Thruxton Red with white stripe. AI, Emgo's, 125's, Shim's, Polaris Bellmouth, K&N.
vanson1200r is offline   Reply With Quote
Old 12-18-2007, 12:53 AM   #8 (permalink)
RonD's Avatar
yeah my bike is not running lean so iam in a different position to start with, and i cant see how putting the snorkel back on is going to make it leaner, i would think richer,but if it did run lean and it should not ,that would mean iam flowing more air ,and an increase in jets size would put it right but thanks for your comments its interesting..
Regards Ron
Old 12-18-2007, 12:56 AM   #9 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
I am sorry you broke your carbs. However, what I find interesting is that your bike went from lean to super lean ...... that would tell me that it was pulling in more air (maybe?).
Wonder what would have happened if you would have followed that path, and simply installed larger jets to compensate for more air?
I'm no tune up expert...just asking a question.
Bob
Old 12-18-2007, 07:59 AM   #10 (permalink)
pabonne's Avatar
Unrelated to the snorkel, just provided impetus to remove the airbox since I had the carbs out already. I broke the carb casting trying to remove the anti-tamper plugs covering the idle mixture screws. DOH!
Maybe I confused things here... I went from lean with the "in-tact" snorkel in place, to even leaner with the trimmed snorkel in place. I never tried it with the snorkel completely removed because I felt like I was just making things worse instead of better.
Probably would have been fine. But I got the carbs from SCCTrim and he through a couple of K&N cones in on the deal. So I re jetted to that set up and the rest is history.
Sprint Engineering Mufflers boxerman Twins Technical Talk 5 02-15-2008 06:20 PM
Sprint Engineering Exhausts mac74 Hinckley Classic Triples 3 10-12-2007 08:38 AM
I've heard of over-engineering, but sheesh! Scottius Twins Technical Talk 10 06-22-2007 07:37 PM
Superior German Engineering R100Pilot Speed Triple Forum 7 10-31-2006 11:19 AM
HMF Engineering carbon can exhaust SurgeonofSteel Speed Triple Forum 5 03-22-2006 07:52 PM
