12-17-2007, 07:51 PM
Powerbike Favourite Bike: Triumph Thruxton
Can't sync me Carbs
I need to sync the carbs but not having much luck. I had to dispose of the mercury while moving and have tried engin oil and ATF and they just get sucked up and can't get a reading. Is there anything that I can use to give a good reading without having to buy mercury. I don't even know where I could buy mercury from.
12-17-2007, 08:01 PM
Powerbike Favourite Bike: 2007 Bonneville T100
Posts: 329 Other Motorcycle: 04 Yam V-Star 1100 (Hers)
Here you go Bro
Itcha,
Call or e mail Larry Snyder at Motion pro. He was incredibly helpful to me as I'm sure he will be to you. The mercury carb sync tools are now distributed by another company. The name slips my mind at present. Larry will be able to direct I'm sure. Here's his contact info:
Larry Snyder
Technical Services
Motion Pro Inc.
P: 650-594-9600 ext. 111
F: 650-594-9610
E: larry@motionpro.com
Cheers,
SK
2007 T100 T&O - AI's off, ARK, K&N's, 42 pilots, 140 mains, 2 turns out, D&D silencers, ACR Adjustable Clubman's, KYB's, WP springs, Thrux gel seat______________________________________________
Who's that little old man with Paul?
12-17-2007, 10:36 PM
Formula Extreme Favourite Bike: 06 Bonneville Black
If you are using ATF or oil, make sure you have a good couple of feet before the carbs of extra tubing. Also let it hang overnight to let all the oil that was in the side to get it into the tube settle to the mid point and none will get into the carbs. I have this setup, and never had an issue. Only thing is go slow and very minor turns at a time with giving a second to stabilize. Also make sure to do not leave the screwdriver on the adjuster screw, as it will give a false reading. Make small turn then pull tool and wait a second to see where you are at.
12-18-2007, 12:15 AM
NewOldSkool
Righto, I think the tubing I have must be to short then, I'll try again with longer tubes, thanks.
Kramrocker,
Thanks also, if all else fails I will give Motion Pro a call but I am trying to avoid the mercury if possible.
12-18-2007, 12:34 AM
Formula Extreme Favourite Bike: Bonneville
I made mine with a 20 ft. piece of tubing. It works well.
 2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
12-18-2007, 12:39 AM
Team Owner Favourite Bike: 2003 T100
Posts: 5,474 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: 2008 Guzzi 1200 Sport
As geolpilot said, you could make an inexpensive manometer and sync them. This approach has been disputed here, but for one reason or another, it seemed to work for lots of airhead BMW riders. It's worked for me on the W650, T100, and the old GS.
if you're interested, and don't know how to make one of these things,drop me a line and I'll send you the info.
bcgilligan@yahoo.com
Bob
12-18-2007, 05:11 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
I bought the electronic (no mercury) carb balancer from Aerostich. It was expensive (US$100) and I haven't used it yet, but other users report good results with it. I'll post my results in the spring when I try it.
Marty
12-18-2007, 05:53 PM
SuperSport Favourite Bike: 1966 Bonnie
Posts: 1,255 Other Motorcycle: Malvern Star
I bought the guage type for AU$70 cause mine where so far out of wack that it kept sucking all the fluid down the left hand manifold.They are brilliant its now a 10 min. job.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
12-18-2007, 11:31 PM
Formula Extreme Favourite Bike: 07 Bonnie Black
Posts: 822 Other Motorcycle: 93 Yamaha GTS Extra Motorcycle: can't afford another
Sync with vacuum gauge
I may be called a wanker for asking this question, but here goes. Can a pair of automotive vacuum gauges be used to sync the carbs or are they too crude??
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
12-18-2007, 11:39 PM
Yep thats all the $70 pair I bought are with a couple of fishtank bubbler valves to stop the needles bouncing.Oh they also come mounted in a nice bracket that hangs over the bars.
