Thanks, Bill - good article. The photo of the float chamber with bowl removed definitely shows the starter jet, but like you said, it may be pressed into place. It bothers me that my bike is such a hard starter when cold compared to some others on this site. It makes me wonder if the time she spent on the dealer's floor without being ridden could have allowed the starting circuit to gum up with gasoline crud, causing the hard cold weather starting. Dealer could have been sloppy about draining or at least stabilizing the fuel (you just know they didn't!)
Maybe the starting circuit in general is prone to gumming up, since I barely use it in warm weather at all, especially since I've switched to slightly larger pilots and mains.
Bob
