Old 11-27-2007   #1 (permalink)
Favorite Bike: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
new bonneville bolt on light kit
I just got mine in the mail...
So i spent a few minutes looking for the front signal OEM plug...and from what i can see...well i couldnt find um...Are the OEM plug wrapped up? That wire bundle seems to go under the tank...is that where the Plug is?
killian101 is online now   Reply With Quote
Old 11-27-2007   #2 (permalink)
Favorite Bike: Norton F1 Sport
DuckMan001's Avatar
Other Motorcycle: 06 Thruxton
Extra Motorcycle: 95 Trophy 1200
It's in the headlight bucket
Never ask a man if he's from Texas. If he is he will tell you. If he isn't there's no need to embarrass him.
DuckMan001 is offline   Reply With Quote
Old 11-27-2007   #3 (permalink)
bsmith222's Avatar
The front signals plug into the wiring loom inside the headligh shell. Follow the leads from the signals and make note of which is left and right.
-brent
bsmith222 is offline   Reply With Quote
Old 11-27-2007   #4 (permalink)
Favorite Bike: My Bonnie!
coelacanth's Avatar
I did this job recently. Really easy. Open the headlight housing and find small plastic connectors. take the OEM cables off and snap new ones in. The cable color on NB's manual might not match the actual color on your Bonnie, but just make sure a black cable goes to a black cable on bonnie's side, and you'll be fine.
07 Bonnie
Black/red T-100 tank with black headlight shell, rear fender eliminated, short front fender, Monza Cap etc.
AI/snorkel removed, UNI filter with TORs. 120 / 40 jets, 1 shim, 2.75 out. EBC HH brake pads.
coelacanth is offline   Reply With Quote
Old 11-27-2007   #5 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
killian101 - I got one of these from Brent and they rock. Like Brent said follow the leads. Check that your blinkers work before you button up the headlight. I obviously didn't do it correctly because all of my blinkers flashed at the same time in a warning lights way. I had to swap around the wiring inside there and it worked perfectly after that.
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 11-27-2007   #6 (permalink)
killian101's Avatar
What about the tape that the wires are wrapped in??? Im guessing i have to cut it??? Then re-wrap with???
Old 11-27-2007   #7 (permalink)
Hedge's Avatar
There shouldn't be any tape just plugs - at least that was the way mine is.
Old 11-27-2007   #8 (permalink)
killian101's Avatar
when i get home...i'll add some pictures...thanks everyone
Old 11-27-2007   #9 (permalink)
killian101's Avatar
ok...so im having trouble with the rear light
So i found the the plug...under the seat and i can see where and how it plugs in(i didnt know i lost a seat bolt )
But, under the fender, where the cable goes through is where im having the problem
that rubber grommet...how do i get that off????
Old 11-27-2007   #10 (permalink)
killian101's Avatar
Thumbs up
got...got um on...i'll post some pix in the morning
Lucas Bolt On Tail Light Kit chieffieldeng Twins Technical Talk 29 04-05-2008 01:00 PM
Do you have a complete bolt-on lighting kit... 2112 Twins Technical Talk 19 07-07-2007 02:23 PM
AI removal kit bolt sizes Healey_100 Club Cafe 4 10-17-2006 12:52 AM
Anyone make a bolt kit for Triumph in Alum. or Ti? brettmess24 Speed Triple Forum 1 04-21-2006 02:11 PM
New Bonneville Bolt On Lucas Style Taill bsmith222 Twins Talk 26 11-23-2005 06:41 PM
