11-13-2012, 03:17 PM
#451 (permalink)
Anyone used Betor gas shocks?
Made in Spain I understand.
Thanks.
11-19-2012, 12:30 PM
#452 (permalink)
Supersport 400 Main Motorcycle: 2005 Bonneville Black
Posts: 100 Extra Motorcycle: 1975 CB550F Cafe'
I have been looking for shocks on Ebay and found an auction for some that came off of a crashed Thruxton. They do not look stock but can anyone tell what they are?
"Only a biker knows why your dog sticks its head out the window."
Keepin' the shiny side up, and rubber side down, since 2005.
11-30-2012, 11:22 PM
#453 (permalink)
Site Supporter Formula Extreme Main Motorcycle: '11 Speed Triple
Posts: 402 Other Motorcycle: '13 Mag Wheel Bonnie
Originally Posted by Perkology
Just a little update here: I've installed my new Works Performance Street Trackers with ARS (adjustable Rate Spring) on my 04' T100, and I must say, I'm extremely satisfied!! The aesthetics are a huge boost, and more importantly, the performance upgrade is unreal! What a difference!!
(I should include that the rear shocks are Thruxton length - I'm 6'3" and wanted some more height. The steering quickened, but I'm also 225 with full gear, so it's not that noticable, and is something I quite like).
I went with the Street Tracker as well. Did you get the double or single spring? I am 6' 2" 230lb and went with a 360mm also.
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
12-12-2012, 02:55 PM
#454 (permalink)
Grand Prix 125 Main Motorcycle: 2005 Triumph Thruxton
Posts: 27 Other Motorcycle: 1970 Honda CT90 Trail90 Extra Motorcycle: 1964 Honda CA105T Trail55
I got a set of the Works Performance Racer shocks from Adrian (adepackett) at his shop in Topanga. He had a set left over from a build project, and he was selling them for a deeply discounted price (about the same as a set of Trackers). Huge improvement! Now I have to work on the front end, and I'm thinking about the Works Performance cartridges.
12-13-2012, 01:43 PM
#455 (permalink)
Grand Prix 250 Main Motorcycle: 2004 Bonneville T100
Went with the double spring. It's' money!
12-16-2012, 11:45 AM
#456 (permalink)
Production 125 Main Motorcycle: 2003 Bonneville
Posts: 8 Other Motorcycle: 2007 Tuono Factory
You just can't beat a good pair of Ohlins!!!
After over a year of trawling Ebay, eventually manged to get a pair of £1500 Ohlins (the fully adjustable type - including hydraulic pre-load), for £550. Almost new. I know not cheap but not that bad for what they are. From the top end Norton special.
Put Hagon progressive springs in the front with heavy weight oil. Still in the build stage and have'nt managed to test ride it yet but can only imagine it will be a huge improvement on the over all handling.
Bike away to Bob Farnham in January for the 903cc bore out and gas flowed head. Just fitted a 170 rear and 130 (17") front on Talon hubs, with 335 front floating disc and 4 pot Brembo. The street rod is starting to take shape. 2 into 1 Zard short pipe, K&N filters, Dyno-jet stage 1 carb kit. Damn this thing is sucking me dry.....
Roll on Spring!!! (it's too feckin cold in Scotland!)
12-21-2012, 03:35 PM
#457 (permalink)
Production 125 Main Motorcycle: 2012 Thruxton
Funkbyte,
I believe those are Ikon Performance shocks; they retail for about $450 new for the black body/springs version:
http://www.newthruxton.com/html/ikon_shocks.html
Paul
01-10-2013, 09:35 PM
#458 (permalink)
Grand Prix 250 Main Motorcycle: 08 Thruxton
Posts: 46 Other Motorcycle: 2004 SV650
I just picked up some Hagon classic shocks from BellaCorse and I was wondering if anyone has any tips on installing. Do i need to remove the mufflers? do i need to jack up the bike and if so what is the best way? thanks!!
01-10-2013, 09:51 PM
#459 (permalink)
Site Supporter Pole Position Main Motorcycle: 2008 Bonneville Black
Posts: 3,455 Other Motorcycle: Spousal 2009 Bonnie Black
I find you need to jack the bike up enough to take some of the weight off the rear wheel. If you try and swap the shocks out one-at-a-time without doing that the bike settles down enough after removing the original that you can't fit the new one on.
Don't know if you need to remove the silencers to get enough clearance to work. Not on my Bonnie, but I don't have those upswept pipes like on your thrux.
I used to be disgusted, but now I try to be amused.
"A fella could pretty much eat his car keys, if they were deep-fried". Billy
01-11-2013, 11:06 AM
#460 (permalink)
would hanging the seat frame from straps attached to the rafters take the weight off? you don't want the whole tire off the ground right?
and thanks for the advice.
