I know you cannot just swap the muffler portion. I think the kink is different in the headers between the Thrux and Bonnie. If your changing the entire system should not be a problem, same motor, same frame. Not sure on the Scrambler whats different besides the side cover.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
