Old 11-19-2007   #1 (permalink)
BBR
Favorite Bike: 2007 Black Bonneville
BBR's Avatar
Unhappy Bad Luck
Just wanted to vent my frustration. My Bonnie Black has had an oil leak twice already and the dealer has tried to fix it. But 35 miles after the second leak she is leaking again. we can't see where the oil is coming from and I have to take it in and drop it off so they can do a powder test to see where the oil is coming from. Problem is they have to wait until it isn't raining which in western Oregon could be March. The dealer is really cool and very helpful, but it still bums me out.
The oil is on the fins just below the plug on the right.
BBR
BBR is offline   Reply With Quote
Old 11-19-2007   #2 (permalink)
Is this leak high or low in the engine and is it on the ground or in the low spots on the case just asking because my 07 hand what appeared to be oil leaking from the jugs down onto the engine case. Dealer couldn't figure it out and someone on here posted about the grease they us to stop rust being packed in the fins and melting as the engine got hot and it would puddle in the low spots on the case. After hunderd miles or so the oil leak seemed to stop cause the grease burned off. Just a thought hope yours is as simple .
Jimmy
JEnfield is offline   Reply With Quote
Old 11-19-2007   #3 (permalink)
BBR
BBR's Avatar
The oil is on the heads (silver edged fins) and some is even spraying back to the carbs and side covers. It has over 6000 miles so that anti-rust film should be all gone. Unfortunately it is definitely oil.
BBR
Old 11-19-2007   #4 (permalink)
Favorite Bike: 2007 Bonneville Black
Head gasket. Bummer.
smartin108 is offline   Reply With Quote
Old 11-19-2007   #5 (permalink)
Favorite Bike: Bonnie T-100 Creamsicle
drharveys's Avatar
Other Motorcycle: Suzuki Boulevard S-40
Or an opportunity to have the heads ported and polished!
drharveys is offline   Reply With Quote
Old 11-19-2007   #6 (permalink)
might just be the valve cover gasket. lots of reported leaks from there, havent heard of too many bad head gaskets
G
I just wanted to ride
Old 11-19-2007   #7 (permalink)
BBR
BBR's Avatar
The cam cover gasket (I think this is the same as the valve cover gasket) has been replaced twice. The dealership hasn't seen anything like this yet. Thank god for warranties.
BBR
Old 11-19-2007   #8 (permalink)
Interested in seeing the final fix, as I have the EXACT same leak.....My dealer said it was the valve cover gasket, and it would be about $100 to replace. I'm going to do it myself though.....Let us know what happens.
Tenover is offline   Reply With Quote
Old 11-19-2007   #9 (permalink)
Favorite Bike: The one I'm riding
Old Scratcher's Avatar
Other Motorcycle: '08 Street Triple (black)
Extra Motorcycle: '06 SuperScram 904 & more
At least your dealer's on side, & it's all happening under warranty. Just keep reminding them how oil-leaks are the first thing people look for when checking out a Triumph, whether they're bike-savvy or not. In fact non-bike people are the worse offenders at it, 'cause it's the one thing they (think they) know about Triumph's, is that they leak oil. So these modern ones just can't do that. Triumph knows this well, & if you keep reminding them as well, I'm sure they'll move heaven & earth to fix your problem.
I'll be interested to hear where the leak's coming from, & why it's happened. So please keep us posted.
"They told me I was goin to have to work for my living, & all I wanna do is ride." Jackson Browne (the Road & The Sky)
Old Scratcher is offline   Reply With Quote
Old 11-19-2007   #10 (permalink)
steviek's Avatar
I had a cam cover leak (more of a minor 'weep', really) on the right side that was fixed under warranty but your description doesn't sound like the symptoms I saw. The mechanic at the dealership told me they'd had more bikes in for head gaskets than cam cover leaks which surprised me, I have to admit, given the relative lack of online reports about same. If you are seeing oil on the fins and it's not obviously coming from the cam cover above them, it's almost certainly a head gasket.
Mind you, that's thrown into doubt by the fact that your mechanic is struggling to figure out where it's coming from, because a blown head is usually screamingly obvious. There aren't too many sources for oil leaks up there, and the cam cover is easy to rule out as you can see the whole extent of it and spot any leaks easily. I don't want to second-guess what the fella with hands-on is seeing and thinking, but if he's mystified then it's either not a head gasket or he's stringing you along. I'd guess the former, because most people are basically decent and honest - even those in the autotrade
Best of British luck with finding and fixing this, chum! It'd be a good idea to make sure the mechanic, if he has to remove the head, checks it for manufacturing faults. On old bikes, a persistent leak could mean the head was veeeeerrrry slightly bowed and could never create a perfect seal, or had 'porous' qualities, which is another way of saying the skimming was substandard and microscopic flaws were forming channels that the oil could escape through (as it's hot as Hades and under a lot of pressure).
In a world that becomes more ordered, regulated and monitored every year, choosing to roar down the road on an impractical, dangerous, and downright glorious piece of machinery is as free as most of us will ever get. Thank God for the motorcycle!
steviek is offline   Reply With Quote
bad luck.....shoot me now. dazco Twins Talk 45 12-24-2005 05:32 PM
bad luck swiss Tiger Workshop 1 11-17-2005 05:29 AM
Luck ran out... mercator Sprint Forum 30 11-06-2005 04:04 AM
if it wasn't for bad luck..... speedboy Speed Triple Forum 2 04-11-2005 08:10 PM
