Old 11-16-2007   #1 (permalink)
Favorite Bike: 2006 Bonnie Black
Louis Liftstick - ever used one?
Hey everyone,
Have you every used (or even seen) a Louis Liftstick?
See (German site):
http://www.louis.de/?partner=hurra&t...nr_gr=10003338
I think something like this will be quite handy to have in a puncture situation, when touring out in the boondocks. Right now, it's basically impossible to get the front wheel off without jacking the front of my bike up a bit, and then putting some wooden blocks below - stuff that can't really be carried around.
It does say for the back wheel only, but I don't see why it can't be used to get the front wheel off the ground by about 4 - 5cm. It could be put on the right side frame down tube, and then turned up a bit with the weight going onto the side-stand.
The rear isn't much of a problem, as I've got a centre stand.
Got any other suggestions?
Ride safe,
ZAQ in NZ
zaqtronic is offline   Reply With Quote
Old 11-16-2007   #2 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
never used one or seen one but looks like a blooddy good idea
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 11-16-2007   #3 (permalink)
Try this one, http://cust.idl.com.au/strop/emerglift.htm , closer too our side of the pond..............
Cheers....................agro
"Whale Oil Beef Hooked"
agro is offline   Reply With Quote
Old 11-16-2007   #4 (permalink)
Favorite Bike: The one I'm riding
Old Scratcher's Avatar
Other Motorcycle: '08 Street Triple (black)
Extra Motorcycle: '06 SuperScram 904 & more
They look like a good idea. I couldn't understand the German blurb, but it looks like it uses the sidestand to counterbalance the jack & achieve wheel lift, which could be why they only recomend it for the back. However if used with a centrestand, I don't see why you couldn't use it on the front wheel, to rock the bike backwards. Definitely a good addition to the tool kit. Though you're still going to have to chock up the bike once the wheel's removed (same as a car), as it's never good to trust a jack for that long.
"They told me I was goin to have to work for my living, & all I wanna do is ride." Jackson Browne (the Road & The Sky)
Old Scratcher is offline   Reply With Quote
Old 11-16-2007   #5 (permalink)
Favorite Bike: Scrambler
panthercity's Avatar
Other Motorcycle: R1150RSA
Extra Motorcycle: R1100RSA
Why would you be removing a wheel on the side of the road in the first palce?
Bob AMA #162726 LPR #54
`02 BMW R1150RSA
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Old 11-17-2007   #6 (permalink)
Favorite Bike: '05 T100
I got a centerstand for my T100. With the front end being so heavy one of these might be handy when used WITH the centerstand. When taking off the front wheel for maintenance I've used a small hydraulic jack under the bracket near the bottom of the front downtubes. It works great (at home). But I wouldn't want its weight or bulk on a tour. That "lift stick" might just be the ticket for the road.
Geimer is offline   Reply With Quote
Old 11-17-2007   #7 (permalink)
Favorite Bike: bonnie
greyplague's Avatar
Other Motorcycle: BSA B 31 1954-for sale
Portugese flat.
Try touring ,get a flat,ask again.
I leave the 'hood now and then. Even in Europe you'll find places where your cellphone is dead, or help hard to get. Try a call for help in a language like Czech or Hungarian...Then find a suitable rock,treestump or the like and fix that flat. Or stay there. Took me two hours (Portugal,rear tire), got under way and replaced the patched tube after that holiday,2500km's later.
Grtz, Thieu.
as for 'german blurb': -height swingarm appr.27.5 cm.
-max. 100 kg.
- useless on choppers with low and long sidestands
look at the pics; the Aussie version looks very homemade,easy to copy.
the German version has a threaded lifting rod , halfway righthand-halfway lefthand threaded with a handle in the middle to get things moving.This means the weight is divided over TWO internal threaded pieces (top,bottom). The Australian tool depends on one nut that'll strip after a short time, due to the welding of the handle on it.Extreme heat does strange things with nuts.(no, I'm not paid by louis.de )
There ain't no such thing as a free lunch.
greyplague is offline   Reply With Quote
St. Louis Area anyone? GrleThruxtn Club Cafe 4 12-31-2007 12:34 PM
Donelson-St. Louis highcard Triumph, Models & Dealers 15 09-28-2007 03:22 PM
St. Louis, MO to Dubuque, IA highcard Ride / Trip Reports 0 08-21-2007 12:41 PM
KC to Saint Louis and back ffemt613 Ride / Trip Reports 1 05-15-2007 06:24 PM
Road Trip - Laredo, TX to St. Louis & points North GrandPaulZ Classic, Vintage & Veteran 0 02-13-2007 11:39 AM
