BikeBandit
Old 11-09-2007   #1 (permalink)
mecscc's Avatar
130 90 17 -------- Ok?
I need a new rear tire. The fairly new front is a Dunlop 404. I would like to match the rear to it since I like the way the front feels. The rear 404 comes in a 90, not an 80 which is the OEM size. I doubt that poses any problems, nor does the indy mech that I get my tires from.
No problem with it????????????
Thanks,
Monte
Monte
"The Old Ohio Preacher Man"
Old 11-09-2007   #2 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
I don't see this causing a problem. Width is the same. Since the "90"is a percentage of width, 130 x .90 = 117mm, instead of 130 x .80 = 104mm. Diff in clearance is approx 13mm, or a half inch. You'll be increasing the diameter of the tire approx 1" total, or increasing the height of the back of the bike about 1/2 inch. You can search for the official Dunlop site and get the actual dimensions of all their tires. Have your indy make sure there's room for a tire that requires 1/2" more clearance from all surrounding parts .... fender, etc.
It should make it easier to get up on the center stand, too. Might steer a little quicker, too.
Bob
Old 11-09-2007   #3 (permalink)
mecscc's Avatar
Thanks, Bob. He did look at it and said it looked like there would be no clearance issues.
It would be nice before I do it to hear from someone who has already done it.
Monte
Monte
Old 11-09-2007   #4 (permalink)
Favorite Bike: '08 White Tiger
I just put a set of Pirelli's on my T100 and used a 130/90/17 V rated on the rear with no problems. It does set a little higher on the center stand and the bikes handles much better than with the oems' !
The older I get, the better I was!
HOGUSERRECTUS is offline   Reply With Quote
Old 11-09-2007   #5 (permalink)
mecscc's Avatar
Thanks! I didn't want to order it in and find it rubs on something or bottoms out all the time (I could, if necessary, I suppose, tighten the preload on the shocks but I like the setting it is on now.)
Appreciate knowing that someone on a similar Bonnie runs 90s and that they are OK.
Monte
Monte
Old 11-09-2007   #6 (permalink)
Retired Legend
sweatmachine's Avatar
the taller rear tire will probably quicken up the steering a bit. A good thing, IMHO.
Old 11-09-2007   #7 (permalink)
mecscc's Avatar
That's fine with me, Sweat. At my age I could use some quickening up.
Seriously, that is no problem from where I sit. Thanks for the tip. Bob mentioned that too.
He also said, as did Owen, my mech, that it probably will make it easier to raise it on the center stand; and with my hands starting to give me trouble now and then that would be an added bonus.
Monte
Monte
Old 11-10-2007   #8 (permalink)
Favorite Bike: 2006 Bonnie Black
got 'em here
Hi Monte,
Yep, I've got Avon Roadriders - stock size up front, and 130/90/17 at the rear.
Fits fine... looks nice n big.
Sometimes I think there's a slight wobble, but it's probably my mind playing tricks on me.
Ride safe,
ZAQ
zaqtronic is offline   Reply With Quote
Old 11-10-2007   #9 (permalink)
forgot to mention
I forgot to mention... I will probably go back to the stock size 130/80/17 next change. The rear usually touches the ground when on main stand, and I can't rotate it freely, to lube chain/inspect bits.
Having said this, it's easy enough to put someting small under one of the main-stand legs... only seems to need a few mm to rotate freely.
Old 11-10-2007   #10 (permalink)
Favorite Bike: My 904 Bonnie
keef's Avatar
Extra Motorcycle: dya mean the one outside?
I have a Mezteler Lasertec 140/80BV17 on the rear and 100/90-19V on the front and, although I'm fairly happy with that, I've been sort of thinking of having 110/90 front and 140/90 rear next time they're due for a change.
It's good to know that I'm not too far from what's do-able.
Rides:
2001 Bonnie: Mods - Wiseco 904; KARK; Togas; Hagon Nitros & Progressives, etc.
The Wife: Mods - haircut; earrings; children
keef is offline   Reply With Quote
130 Horse T3 Sprint! KitNYC T3 Sport / Touring Forum 9 11-12-2007 04:35 PM
Modified Bonnie to 130+ HP! Brooksie Twins Talk 9 06-21-2006 04:25 PM
Bonneville 130 & 150 mph club AlaskaSprint Sprint Forum 15 05-02-2006 07:45 PM
125 mains to 130 dowop Twins Talk 0 04-09-2006 05:58 PM
