I did this install in about 5 min. The directions go into great detail about taking the gas tank off, disconnecting the battery terminals and various other nonsense. I simply undid the 2 tank bolts in the back, lifted the tank up and slid it slightly to the side. I then pulled the Aux wire out of the snake and pulled it straight back toward the seat. I put the tank back down, secured it with the 2 rear screws and then routed the Aux wire down the right side and and plugged it into the outlet that I attached on that bar near the carbs as it is shown in the directions. Honestly, it's simple.
Poweroutlet is your one stop shopping for adapters -
http://www.powerletproducts.com/products/cables.php
I recommend an assortment such as:
CIGAR ADAPTER - PAC-001
"Stubby" connects any device that has a cigarette type plug to a Powerlet socket (BMW type), including cell phones, radar detectors, air compressors, etc..
PL/2SAE "Y" CABLE - PAC-006
Plug two heated vests into your motorcycle without adding an extra socket! Approx 8" long.
PL/SAE CABLE - PAC-008
Manufactured with a basic plug (PPL-001) and 18awg wire. Plug style can be seen on the plugs page.
1 CIGAR & 1 POWERLET SOCKET - PAC-029
Connects any two devices to a Powerlet socket. Approx 10" & 12" long leads.
