Old 11-01-2007   #1 (permalink)
Favorite Bike: 2006 Triumph Scrambler
Scrambler stock handlebar specs?
Hi all,
I'm wondering if someone knows the specs on the stock Scrambler bars? I can get a width measurement easily enough, but the other measurements (rise, height, pullback) are not as easy with the bars on the the bike and controls in place. I had found the specs for the Bonneville bars, but have yet to find them for the Scrambler.
Any help would be appreciated!!
Thanks.
blackplag is offline   Reply With Quote
Old 11-01-2007   #2 (permalink)
PfM
Favorite Bike: 1961 Triumph Thunderbird
PfM's Avatar
Other Motorcycle: 1959 Triumph Tiger 110
Extra Motorcycle: 2006 Scrambler
Why ? - they are rubbish.
Chuckem.
I do have a set in the shed that I will measure up as best I can if nobody has them handy.
Cheers
PfM is offline   Reply With Quote
Old 11-01-2007   #3 (permalink)
PfM,
Thanks for the reply.
I actually like the riding position that they provide, so wanted to replace them with something similar, but in black with a welded cross brace (personal aesthetic preference while still maintaining ride position). Though I do like the look of lower bars, I worry they may lead to discomfort on longer rides.
Old 11-01-2007   #4 (permalink)
PfM
PfM's Avatar
Not sure you would find anything similar. They appear to have almost no pullback.
I replaced mine with some aftermarket ones described as "British Touring Bars" which are basically the same as the ones on the 60's models (not the American bars though). I am 5' 10" and find them fine comfortwise and much more pleasing to mine eye.
I'll measure.
Old 11-02-2007   #5 (permalink)
PfM
PfM's Avatar
OK, not sure about the proper way to measure these, so here goes:
(Dimensions in old money)
Height to end of the bend (from bottom of tube) - 5
Height at end of bar - 7
Width tip to tip - 31.25
Pullback to centre of tube - 2.25
You would be able to get what they call "high bars" for an enduro bike (xr400 say) with similar width and height, but I am sure the pullback would be more....which is a good thing.
Try Renthals
Old 11-02-2007   #6 (permalink)
PfM,
Much appreciated, thanks!
I agree with your recommendation on possible replacements, that's where I'll start.
Thanks again.
Old 11-02-2007   #7 (permalink)
Favorite Bike: T100
lewilewi's Avatar
Other Motorcycle: Fazer
Scrambler stock handlebar are 22mm or 7/8th
stock bonnie bars are 25mm or 1 inch
I was gunna swop but they would nt fit .
I using a low drag bar very close to the scramble bars but cheaper
lewilewi is offline   Reply With Quote
Scrambler stock handlebar dimensions Brumos Twins Technical Talk 3 08-23-2007 08:36 PM
Bonneville Handlebar specs Benthicmerc Modifications & Workshop Talk 1 07-05-2007 02:27 PM
'98 Adventurer handlebar specs duff Hinckley Classic Triples 5 03-08-2007 06:45 AM
handlebar specs for 03 S3???? nakedlover Speed Triple Forum 6 02-27-2007 04:18 PM
2003 SP3 stock handlebars specs?? lofathd Speed Triple Forum 2 04-17-2006 08:54 PM
