BikeBandit
Old 10-24-2007   #1 (permalink)
Favorite Bike: '04 bonneville black
exhaust leak
Although I have had my D&Ds for some time I am just now noticing an exhaust leak right where the slip on mights the header. I tried turning the clamp 180 and wrenchin' down then turning 180 again and wrenchin' down again and the leak is still there.
Any suggestions?
Thanks
TJ
'04 bonneville black, AI removed, airbox removed, D&D pipes, 150/45 jets
rockinokie is offline   Reply With Quote
Old 10-24-2007   #2 (permalink)
High temp RTV in the joint
2006 T100 Tangerine
1984 BMW R100RS
1972 NORTON COMBAT COMMANDO
1966 R60/2
jerryb is offline   Reply With Quote
Old 10-24-2007   #3 (permalink)
bendavanza's Avatar
hi temp rtv , correct!
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 10-24-2007   #4 (permalink)
Thanks guys! I'll try it out tonite.
TJ
Old 10-24-2007   #5 (permalink)
Favorite Bike: bonnie
greyplague's Avatar
Other Motorcycle: BSA B 31 1954-for sale
I use non-hardening gasket sealer, picked it up on a garage sale-50 cent deal. Works fine, no more leaks or black staining and I convinced myself the bike pulls better (50 cents worth better, anyway).
Grtz,Thieu.
(permatex 2 form-a gasket sealant-loctite. Part NO.2C)
There ain't no such thing as a free lunch.
greyplague is offline   Reply With Quote
Old 10-24-2007   #6 (permalink)
Me too
I've got the same thin happening on the drive side with my TORs. I'm a learner though, what's hi temp rtv?
_____
'06 Thruxton, black, AI removed, TORs, hacksawed battery box and K&N's, 42/142.5's, one shim, 2.0 turns out, tri-bar headlamp with Hella yellow bulb, bad attitude
Monkey1 is offline   Reply With Quote
Old 10-24-2007   #7 (permalink)
Hey Monkey1, RTV is a silicone. Room Temperature Vulcanizing. You can pick it up at auto stores.
TJ
Old 11-30-2007   #8 (permalink)
Thumbs up
Thanks TJ, I totally forgot about this thread and came back to it today. With the freezing temps I've got I'll have plenty of time to shop for some RTV and knock this out come spring.
_____
Old 11-30-2007   #9 (permalink)
Favorite Bike: 2007 Bonneville T100
Kramocker's Avatar
Other Motorcycle: 04 Yam V-Star 1100 (Hers)
How can you tell?
Rock,
I too have the D&D's. How can you tell there's a leak? Do you hear it? Can you feel it? Is it coloring the cans, connector or pipe? Just want to know what to look out for down the road.
Cheers,
2007 T100 T&O - AI's off, ARK, K&N's, 42 pilots, 140 mains, 2 turns out, D&D silencers, ACR Adjustable Clubman's, KYB's, WP springs, Thrux gel seat______________________________________________
Who's that little old man with Paul?
Kramocker is offline   Reply With Quote
Old 11-30-2007   #10 (permalink)
Favorite Bike: The one I'm riding now.
gonzo'st100's Avatar
Other Motorcycle: Vespa 150 Scooter
High Temp Silicone...if you use it, make sure you give it time to cure before turning on the engine. Overnight will be fine.
gonzo'st100 is offline   Reply With Quote
Exhaust Leak NYTBird The Rocket Science Forum 12 11-13-2006 08:32 AM
Exhaust leak quagmire Classic, Vintage & Veteran 10 08-31-2006 03:35 AM
Exhaust Leak................ ken750f Speed Triple Forum 1 10-15-2005 08:24 AM
Exhaust Leak paulie Tiger Workshop 8 02-08-2005 08:43 PM
Exhaust Leak RalphS Sprint Forum 2 05-14-2004 10:37 AM
