I really like the look of the oil temp gauge!
Just a bit worried that if I got one, it's the sort of thing a brainless oppertunist might nick.
Still thinking about it though.
Does anyoneone know what sort of oil tempretaure range the bonnie should be running at?
I haven't seen anything in the blurb for the gauges or in any of my manuals, but it would seem something you need to know if you had one of these gauges.
