Old 10-18-2007   #1 (permalink)
Favorite Bike: Triumph Bonuxton
DrewDesign007's Avatar
Other Motorcycle: N/A
Extra Motorcycle: N/A
Tail light only works with foot brake
Any suggestions? - got to figure it out before my AM commute-
Scored as a rocker!
75% rocker - 50% mod
DrewDesign007 is offline   Reply With Quote
Old 10-18-2007   #2 (permalink)
you need a new bulb..it is a dual filament and you've blown the tailight portion...
should be able to pick one up at any gas station...
greytop is offline   Reply With Quote
Old 10-18-2007   #3 (permalink)
JAXTRIUMPHGUY's Avatar
Use both brakes...
2005 Hinckley Bonnie
JAXTRIUMPHGUY is offline   Reply With Quote
Old 10-18-2007   #4 (permalink)
Whew...I thought it was something major.
I use to have a 74' Triumph Spitfire- talk about Lucas electric! Sheesh!
Glad to hear that - thanks gentlemen!
Scored as a rocker!
Old 10-18-2007   #5 (permalink)
bonnieblackinfl's Avatar
Check your front brake switch connectors up at the lever, pehaps they worked loose. It is not uncommon for these little POS microswitches to go bad too. I think they are $17 at the dealer.
Greg
bonnieblackinfl is offline   Reply With Quote
Old 10-18-2007   #6 (permalink)
I wonder if I tweaked it when I installed the SuperBars...
Scored as a rocker!
Old 10-18-2007   #7 (permalink)
oregonthruxton's Avatar
Hey Drew, you lost your tan.
'04 Thruxton
oregonthruxton is offline   Reply With Quote
Old 10-19-2007   #8 (permalink)
Maybe I'm reading something wrong - but a TAIL LIGHT is on when the key is on. The BRAKE LIGHT comes on when either the right side hand lever (the front brake) or the right side foot lever (the rear brake) is engaged. It helps if you use the proper terms.
If you recently put on some handlebars by yourself and now your brake light doesnt work when you engage the front brake - then yeah - chances are you goofed something up.
Bonafide is offline   Reply With Quote
Old 10-19-2007   #9 (permalink)
yep, I would say so and that would be the first place I would look.
Old 10-19-2007   #10 (permalink)
Clarification:
The Hand Brake does not illuminate the STOP (brighter state) of the tail light. but the Foot Brake does - The RUNNING light is on regardless.
Which leads me to believe I tweaked the front brake switch connector or microswitch. Regardless it forces me to use the foot brake more diligently so I guess it's a good thing for now.
I'll let the dealer hash it out when I drop it off for the leaking cam cover.
Scored as a rocker!
NB FEK installed, brake light works no running light pbcurran Club Cafe 9 10-25-2007 02:20 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 09:21 PM
Woohoo! My brake light works! T3 Sport / Touring Forum 1 08-20-2005 08:39 AM
Trident Tail / Brake Light pyspilf T3 Sport / Touring Forum 2 07-01-2005 03:32 AM
Foot brake light doesn't dim Triumph SuperSports 13 10-22-2004 07:14 AM
