Old 10-16-2007   #1 (permalink)
Favorite Bike: my 1969 TR6C
Scrambler..new tires, steers differently
I just switched out my Knobbies on the Scrambler for some of the Metzeler Tourances, which is a way better tire, but I notice that the steering feels so much stiffer. Just not as light as when I had the knobbies on there. Is it possibly cos there'e more rubber on the road now?
clamp007 is offline   Reply With Quote
Old 10-16-2007   #2 (permalink)
Favorite Bike: Bonnie
BrianM's Avatar
Other Motorcycle: Moto Guzzi V11 Sport
Extra Motorcycle: Wife's H-D Sportie
Bump. I'd like to know too :-)
'06 Scrambler: TORs, AI / baffle plate removed, 19t sprocket, 115 mains. No blueing, no popping.
BrianM is offline   Reply With Quote
Old 10-16-2007   #3 (permalink)
Retired Legend
sweatmachine's Avatar
is the rear tire lower profile, or the front tire taller profile? It will affect the rake/handling characteristics.
Try loosening your triple clamps and raising the fork tubes about 5-10mm. It will quicken the handling back up.
here's a pic of my bike, you can see the fork tubes raised above the top clamp:
Old 10-17-2007   #4 (permalink)
bovefrankj's Avatar
Did you stay with stock sizes? I recently fitted Tourances and the steering quickened slightly. Pressures okay? I run 31 psi / 34 psi.
bovefrankj is offline   Reply With Quote
Old 10-17-2007   #5 (permalink)
Favorite Bike: 06 Scrambler
I went with the Metzeler Tourance tires on my Scrambler and run the same air pressure as the T 100/Bonneville series bikes. 33 psi front and 38 psi rear and my handling and ride are about the same as the T 100. They stick really well in the tight corners and a much better ride all around. I did stay with the stock size.
larryshep is offline   Reply With Quote
Old 10-17-2007   #6 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Went the other direction
Not on a Triumph Scrambler. But I ran street Metzelers for years on my BMW R100GS, switching to Metzeler Tourance (knobbies) a few years ago. the steering is much lighter than with the street tires, so much so that initially, I had to be careful not to let the bike fall too far into a corner. Now that I'm used to the knobbies, I like the additional mileage I get, and have found the Tourances to handle some fairly steep lean angles. it is also very easy to make mid turn corrections to my line.
Bob
Old 10-17-2007   #7 (permalink)
I installed Metzeler Tourance's on my Scrambler and felt the same thing. The steering tightened, not slowed. With the stock tires the steering had a very light feel, but gave very little feedback because of a lack of overall grip. The Tourance's have a ton more grip so they provide more feedback to the rider, a tighter feel...not slower response.
McQueen278 is offline   Reply With Quote
Old 10-17-2007   #8 (permalink)
I guess there are some differing opinions. I did go 1 size up on back & front, so have a 140/80 on back & a 110/90 on the front. It's not supposed to make any difference really, as it's a minor change. Don't get me wrong, the bike still feels good, but just feels a little different.
Scrambler Tires gt1jimi Twins Technical Talk 22 06-06-2007 02:13 PM
New Tires -- Scrambler McQueen278 Twins Technical Talk 11 03-30-2007 05:14 AM
Scrambler tires? scramblerrider Twins Technical Talk 1 10-10-2006 11:56 PM
Salespeople treat women differently stellasue Triumph, Models & Dealers 14 08-25-2006 09:32 PM
Scrambler Tires Badhorse Twins Talk 3 04-25-2006 10:17 AM
