Motorcycle.comAdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
Old 10-12-2007   #1 (permalink)
Favorite Bike: Triumph Bonuxton
DrewDesign007's Avatar
Other Motorcycle: N/A
Extra Motorcycle: N/A
Naps End don't fit into SuperBars
Not a tight fit - how do I remedy this for installation?
They wiggle, shouldn't they be a tight fit?
Scored as a rocker!
75% rocker - 50% mod
DrewDesign007 is offline   Reply With Quote
Old 10-12-2007   #2 (permalink)
fender's Avatar
I used 3/4" silicon tubing from the hardware store. Cut it to the length of the rubber end that slides in the bar and then make a cut down the length of the tube section. It fills out the gap enough that when tightened down it won't move.
fender is offline   Reply With Quote
Old 10-12-2007   #3 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
A piece of thin walled pvc
I have used a piece of thin walled pvc pipe split from home depot many times for bar end install shims.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
SuperBars NoDice Hinckley Classic Triples 0 01-13-2008 11:36 AM
Making 7/8 Bar End Mirrors fit our Handlebars DrPangloss Twins Technical Talk 8 11-22-2006 06:08 PM
Need Bar End Expansion Bolts for new Superbars - Advice? GParks Twins Technical Talk 3 08-14-2006 05:24 AM
Radiator end cap question: what models fit? Mojoinco Hinckley Classic Triples 4 05-09-2006 12:45 AM
will a 750 top end fit on 650 cases Modifications & Workshop Talk 3 02-27-2004 12:36 PM
