Motorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 10-12-2007   #1 (permalink)
Unhappy My ignitor is dead
A new one has to be shipped from England apparently so there's another weekend without my Bonnie. Shipping will take 5-6 days!! I guess it's coming by boat.
Has anyone else had this happen? What does it do? It costs $500!! Yikes!!
bonnienewbie is offline   Reply With Quote
Old 10-12-2007   #2 (permalink)
grayghost's Avatar
Wink
It's the sealed small black ignition module that resides under the seat. It sends the "spark" at TDC (Top Dead Centre) on the power stroke of the piston, to the coil, the coil in turn increases the voltage WAY UP (read 30,000v +), the current passes from the coil through the ignition wire where it jumps across the gap on your spark plug.
It's a sealed unit, maintenance free, and it either works or it doesn't.
Likely costs $ 15.00 to manufacture, $ 10.00 to package, inventory, and run it through the distribution network, and with MARK-UP sells out for $ 500.00
" No.....your other left" (Memories to when I was a Motorcycle Instructor)
grayghost is offline   Reply With Quote
Old 10-12-2007   #3 (permalink)
I'd love to get inside one thats gone bad and see whats in there and check to see what may be wrong. Possibly it's a chip and no other components. But if there are other components it might be worth looking into one to see if they are simply diodes or something along those lines that are going bad and then it may be fixable. So many have had to fork out $500 for what could possibly just be a simple fix. of course Triumph isn't going to tell you that.
Old 10-12-2007   #4 (permalink)
Favorite Bike: '05 T100 Black & White
MotoSayle's Avatar
Other Motorcycle: '08 FLHTP
Cool Ignite me
http://www.gill.co.uk/products/digit...n/ignition.htm
Maybe you can bypass Triumph and go straight to Gill.
....Confidence in the face of risk ! ....
MotoSayle is offline   Reply With Quote
Old 10-12-2007   #5 (permalink)
Limited Access
looks like the same unit to me from the pics. is that why you posted that link?
Skint is offline   Reply With Quote
Old 10-12-2007   #6 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
Since it is dead, anyway
Have you considered, getting one from British Customs? it is cheaper andhas a higher rev limit. I think I'm going to this if / when mine goes.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-12-2007   #7 (permalink)
Is this a common problem? I only have 23,000km on it. Does anyone know of a cheap replacement that would work? I'd like to keep a spare if they are problematic.
Old 10-14-2007   #8 (permalink)
stu
Favorite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 2002 Sprint ST
You can pick up a Procom Igniter (what BC sells) for 100-125 on E Bay. It also advances timing 3 degrees and raises the rev limiter on 790cc motors to 8400RPM. It is a straight plug in substitution. However, I have run into hot starting problems with two of them, but they were replaced without question after calling their Sales Dept. The statement they either work or don't is incorrect based on my own experience, at least with Procom units
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
stu is offline   Reply With Quote
T3 ignitor T1290066 willyt Hinckley Classic Triples 15 05-15-2008 08:13 PM
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 12:37 AM
Adventurer with (another) ignitor problem ............ arnoldinup Hinckley Classic Triples 1 06-14-2007 10:32 PM
Ignitor Question - 99 Legend Hagrid Hinckley Classic Triples 4 07-07-2005 02:45 PM
Ignitor Question Hagrid Modifications & Workshop Talk 1 07-06-2005 12:03 PM
