» Links |
10-12-2007
SuperSport Favorite Bike: Triumph Bonuxton
Posts: 1,015 Other Motorcycle: N/A Extra Motorcycle: N/A
Tips for Grips
How do I get my grips off?
Scored as a rocker!
75% rocker - 50% mod
removing grips
There are tons of threads on this, but most of them are boiled down to this:
1. The elegant way, which is to carefully slip a thin screwdriver under the grip, followed by the little red straw attached to a WD-40 spray can. Just one little squirt, a few twists and off it comes. If you are reusing the grips, be sure to wipe out the WD-40 so it does not interfere with a good grip when it is put back on.
2. The destructive approach, which is to cut it off with a utility knife. This inhibits reuse to some extent.
10-12-2007
Supersport 400 Favorite Bike: 2007 Bonneville Black
If you have access to an air compressor you can remove and replace grips in mere seconds. Of all the ways I've done it over the years, this is by far the easiest.
2007 Bonneville Black ~ EPCO Exhaust, Superbars, Center Stand, & Factory Tach Kit.
10-12-2007
Cool - thanks man.
Do I need adhesive when putting the old grips on my new bars?
Scored as a rocker!
10-12-2007
Site Supporter Formula Extreme Favorite Bike: 06 Bonneville Black
No, just slide them onto the new bars. They will stick just fine. And it won't be the end of the world if you cannot get all the WD40 off too. I used it to get them back on to the new bars, and it will dry out and stick fairly quickly.
Mondo
Iraq is stupid!!!
10-12-2007
You don't need any adhesive, since the rubber grip will readily stick to the chrome bar, but some people have used hairspray to slip the grip back on, and when the alcohol evaporates, it acts like a glue. There are also aftermarket products specifically for this, but I have not found any need for them.
10-12-2007
How do I get my grips off? I don't. The factory grips are fine with me, and I don't feel like dealing with it.
Please don't tell us that you're putting white grips on! Please! Wasn't it you that was looking for whitewall tires too?
Marty
10-12-2007
SuperBike Favorite Bike: 03 T100 989
no white grips .only pink grips will do .lol
10-13-2007
I'm going for a magenta really...
Scored as a rocker!
10-13-2007
Posts: 139 Other Motorcycle: '01 Goldwing 1800 Extra Motorcycle: '03 SuperHawk 996
Easiest way I've found is to put a drop of liquid dish soap on the head of a flat screwdriver, slide it up inside and run it around once or twice, then the grip will just pull off in your hand. Wipe the bar down with alcohol, allow to dry, then spray with hairspray and slip grip on. That's it, you're done...
Lance
