Shorter Grips - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-11-2007, 10:58 AM   #1 (permalink)
Favourite Bike: 07' Bonnie
Jhtjon's Avatar
Shorter Grips
When installing shorter grip I assume that the throttle will need to be shortened? Is there a good way to do this? I am going to be installing grips that are 4.25" approx. 1/4-3/8 shorter than stock.
Secondly, if I were to purchase new grips from Triumph do they come with the throttle?
BIR #248
Like my Buddy Roxy said "Yeah I've Got Some Mods"
http://i82.photobucket.com/albums/j2...0072009003.jpg
Jhtjon is offline   Reply With Quote
Old 10-11-2007, 04:40 PM   #2 (permalink)
Favourite Bike: 2001 Sky Blue Bonneville
To shorten your throttle nad by that I take it you mean the white plastic tube inside the grip? Then use a junior hacksaw or any fine tooth saw and remove any burrs once cut.
Will Triumph supply this white tube with the new grips - doubtful unless you order it aswell - it's a separate item
Ian
Skyblue62 is offline   Reply With Quote
1" shorter shocks ? happyray Classic, Vintage & Veteran 5 02-15-2008 05:33 AM
Life Is Shorter Than I Thought...... Lee Biker Hang-Out 23 01-18-2008 03:31 PM
Shorter tail section Piersurf Triumph SuperSports 7 10-23-2006 05:15 PM
Shorter shock for a Speed Four BigPappa Triumph SuperSports 4 12-28-2005 12:32 PM
Shorter Windscreen Trophy 13 03-22-2005 07:25 AM
