Replacing throttle tube and grips. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-29-2007, 08:16 PM   #1 (permalink)
Favourite Bike: 2004 Bonnie Black
Fraederichs's Avatar
I'm going back to the OEM grips from football grips (I want the clean look of the originals) and the new throttle side comes with the inner tube. It requires the cable being switched out and I've read this requires finesse. Can anyone offer me any help with this job? Is there anything to know about opening up the throttle/brake line/etc. housing?
Fraederichs is offline   Reply With Quote
Old 09-30-2007, 04:42 PM   #2 (permalink)
bluheeler's Avatar
Remove 2 screws to open the housing. One on the front in a recess the other is underneath.
Once the housing is opened twist the throttle open.
Carefully clamp needle nose vise grip pliers to the upper cable.
Use just enough clamp force to hold the cable and keep it from sliding - do not crush the cable.
After the cable is clamped release the throttle slowly until you have enough slack to work the cable out of the holder.
Now hold the end of the cable, at the disc, and release the vise grips.
Slowly let the cable back while twisting the throttle closed.
You should now have enough slack to remove the lower cable.
Remove the old sleeve and install the new one.
Reinstall the cables by reversing the above instructions.
06 Bonneville Black
03 V-Star Custom
bluheeler is offline   Reply With Quote
Replacing throttle cable on TT600? MickyC Triumph SuperSports 9 06-19-2007 05:57 PM
New 1/5 turn throttle tube- 1st Ride kiel Speed Triple Forum 2 06-19-2007 01:30 AM
Anyone use a 1/5th turn throttle tube (pic) kiel Speed Triple Forum 6 06-09-2007 06:29 PM
Replacing grips/grip warmer kelticwolv Sprint Forum 3 01-24-2005 12:59 PM
Any Tips for Replacing Grips? MikeWS1 Sprint Forum 7 04-03-2004 10:29 PM
