Go buy set of dog leg offset closed end wrenches
they are box end and have the box set to the side and flat about 1", these will remove the tubes slick as a whistle, plus very handy for bike work. And for penetrating oil there is only 1 good one, Aerokroil, from Kano laboratories, this stuff is the smallest oil molecule commercially produced, will slide through a gap 1 millionth wide. It is also the best carbon,and varnish cleaner you will ever find, makes pb blaster and wd-40 look like water!, and is safe for all weird alloys, it was developed for the aircraft industry for use in freeing exotic metal fastners. It will not stain any metals like a lot of the penetrant cleaners will. (no I don't own stock, but I give cans away all the time, also the BEST cleaner for guns will cut the hard carbon fouling better than any thing and is safe for all finishes, if the barrel is leaded soak with this stuff leave a day or two an just brush out the lead.)
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
Reason: added
