AdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Old 09-27-2007   #1 (permalink)
Favorite Bike: Triumph Bonuxton
DrewDesign007's Avatar
Other Motorcycle: N/A
Extra Motorcycle: N/A
Slide
Sometimes I feel like the back end is slipping out from under me, does anyone else have that problem going into corners?
I have 950 miles on her, stock eveything except for pipes basically.
Generally the backroads I take to work are poorly paved, twisty and uneven.
I know we don't have a fat back tire like the HD guys but this is a big distraction when I ride - is it my air pressure - tire looks good to me.
Maybe up grade the shocks?
Maybe it's my inexperience...yeah come to think of it...
Scored as a rocker!
75% rocker - 50% mod
DrewDesign007 is offline   Reply With Quote
Old 09-27-2007   #2 (permalink)
Favorite Bike: R1200ST BMW
GoldenJubileeBonne's Avatar
Other Motorcycle: Golden Jubilee Bonneville
Drew,
I'm not sure I understand your question about back end slipping out from under you? If you're entry is a little too hot and your using a lot of front brake, you might be unloading the rear tire. This could cause the rear end to lose some traction w/ the road surface. You might try braking sooner in your approach to the corner, balanced front and rear (actually less rear than front) braking, and see if that helps.
I'd look at up grading your suspension, tho as a possible way to remedy the problem.
Hope this is helpful,
Len
GoldenJubileeBonne is offline   Reply With Quote
Old 09-27-2007   #3 (permalink)
Favorite Bike: 2006 Thruxton "Zoe"
mr_badda_bing's Avatar
Are you down shifting coming into the corner?
Are you shifting coming out of the corner?
Rear Brake, Front Brake, Both?
2006 Thruxton - Zoe Yellowbike
125 main jets, 42 pilots, 1 shims, 2 turns, HARK (homemade airbox removal kit) EMGO Reverse Cones, 17T sprocket. 4700 Feet Above Sea Level
mr_badda_bing is offline   Reply With Quote
Old 09-27-2007   #4 (permalink)
slip
Try sitting back further on the seat? Mine sticks like glue!! Even w/ almost bald tire.
CAPT D
Old 09-27-2007   #5 (permalink)
Favorite Bike: 2002 Triumph Bonneville
TheBoatDude's Avatar
Throttle Position?
Hi Drew -
I do experience that a bit at times. I would reckon that the road surface could be a factor. When you experience this, are you on throttle? Off throttle? I'm told that - if nothing else - the throttle needs to be at least slightly cracked so that the bike weight will transfer to the rear tire (the one with more tread on the ground).
[I defer to Twist of the Wrist II for a more technical explanation of that concept]
Hope this helps.
TBD
"...it's a Gin and Gin...it's like a Gin and Tonic, only you use Gin instead of Tonic..." --Dr. Caroline Todd, East Hampton Hospital Trust--
TheBoatDude is offline   Reply With Quote
Old 09-27-2007   #6 (permalink)
I got my Bonnie used from a fellow that foolishly applied Armour-All to both tires including the tire tread. I'm guessing that this isn't your problem. If you want to feel a rear tire slide - liberal application of Armour-All will do the trick.
Steve
Husk01 is offline   Reply With Quote
Old 09-27-2007   #7 (permalink)
remember to brake before you start leaning - assuming you're braking into these corners. if you are on your brakes as you lean into the corner you can easily lose traction, and the rear is usually the first to go. Also remember not to shift in a corner.
It's most likely that - ride 15 or 20 thousand miles and you'll get there.
Mattrat is offline   Reply With Quote
Old 09-27-2007   #8 (permalink)
That's it - that's what I'm doing.
Man...I need someone experienced to ride with. Dang it all.
Scored as a rocker!
Old 09-27-2007   #9 (permalink)
You do need to check tire air pressure at least every other week. I find that over two weeks my tires will drop 3-4 psi. This makes the rear end feel squirrely.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline   Reply With Quote
Old 09-27-2007   #10 (permalink)
Favorite Bike: 2007 bonnie black
Drew, did you take the MSF course, sounds like you did not, you need too, its good and teachs you these things. I took it, since this was my first bike.
jfenton is offline   Reply With Quote
Xmas slide Trumpet D666 RAT - United Kingdom 2 12-24-2007 03:56 PM
need to slide my bike sideways kc5deb Sprint Forum 17 10-13-2007 02:13 PM
Drilling the slide????? bung1 Modifications & Workshop Talk 9 09-01-2007 09:03 PM
Slide drilling negatives AVMECH Twins Technical Talk 14 03-25-2007 12:15 PM
Thunder Slide , Lightweight Slide ?? FEDCT Club Cafe 0 05-26-2006 08:46 AM
