If there are one- hitter pipe looking things with a hose coming out of the head right by the Spark Plugs, you're AI is intact. They replace the AI with a small bolt.
2005 Bonnie Black
2006 Goodwood Green Bonnie
1989 Honda GB500
I saw that you are over the first service interval...I went to 750 miles before I got it. You'll be OK, just take it easy, check and add oil if needed, check the chain, maybe a little lube there.
2005 Bonnie Black
1989 Honda GB500
