Keihin 35mm Race Carb Question
I am having the Keihin 35mm Racing Carbs installed. My freind installing them has explained to me the spicket is too short and the carbs look like they are not securely installed even with the brace from the air box elimin. kit. It appears as if the spicket needs to be about 4mm longer in order to get a good bite. Yes the "O" rings are installed.
Has anyone else had them installed? Any suggestions?
"What are you rebelling against?"
"What have you got?"
