Motorcycle.com
Old 09-10-2007   #1 (permalink)
Favorite Bike: 2000 FatBoy (first love!)
Other Motorcycle: 2007 Thruxton
Extra Motorcycle: 2005 Suckerpunch Sallys B
Question Thrux/Bonne left switch housing removal ?
My bike fell over in the garage (and why wouldn't it, it had nearly 1,000 miles on it) and the turn signal switch on the left clip-on broke, so I purchased a new one. I'm installing the new one now.
The switch has two plugs--the big one that plugs into the wiring harness in the headlight housing and a smaller one that plugs into the lever housing. My question: Do you remember how to get the existing smaller one out of the lever housing? Is there a little "button" I need to push somewhere? Do I just yank it? Just don't want to break anything, and I've pulled pretty hard to no avail.
Thanks!
Thrux666 is offline   Reply With Quote
Old 09-10-2007   #2 (permalink)
Favorite Bike: 2001 Sky Blue Bonneville
Not sure
I'm not sure about the Thruxton switch as my Bonnie is hard wired - no plug just solder.
The majority (if not all) of Triumph connectors have some form of release mechanism, as you say a lever or catch of sorts
Ian
Skyblue62 is offline   Reply With Quote
Old 09-10-2007   #3 (permalink)
Favorite Bike: 2007 Thruxton
tomville's Avatar
When I replaced the whole left side control unit I wasn't too concerned about damage so I took a flat-head driver to it and it eventually popped out. Unfortunatly, I don't recall what the mechanism was (there was one as the new plug snapped in nicely) but I can take a look at the one that I yanked off when I get home.
tomville is offline   Reply With Quote
Old 09-10-2007   #4 (permalink)
tomville's Avatar
OK, i just had a look and it's painfully simple. On the underside of the part the clutch lever attaches to, right where the plug is, there is a small window. Use a screwdriver or anything else that fits to push up. There is a tab on the plug and with a little tug it will pop right out.
I hope this makes at least a little sense. It's been a long day.
Old 09-11-2007   #5 (permalink)
Yep--got it--little window on the bottom. She's now good as new.
Thanks all.
Plugged switch slot in left controls 4N099 Sprint Forum 13 12-20-2007 08:34 PM
07 Tiger Switch Housing bomber13 Tiger Workshop 5 05-08-2007 07:20 PM
converting thrux front end to bonne kidkazi Twins Technical Talk 6 02-16-2007 11:08 AM
Is there a switch for the covered slot on the left-side housing? Curmudgeon Speed Triple Forum 14 01-22-2007 11:42 AM
Right Handlebar Switch Housing Wadejesu The Rocket Science Forum 2 11-07-2005 10:26 AM
