Old 09-08-2007   #1 (permalink)
To drill or not to drill...
Hi Triumpheteer's
I posted last week for words of wisdom before I modded my 865 T100.
Recieved lots of info and finally decided on TOR's, jenks bellmouth,unifilter, 125 mains and 3mm hole, but then amanger advised me not to drill if I'm not fitting pods.
So the question is should I drill, as there's no going back if I do!
steve
always look on the bright side of life.................
19554 is offline   Reply With Quote
Old 09-08-2007   #2 (permalink)
webonnielad's Avatar
I drilled mine and it improved the throttle response.
If you look at my signature (ok it's for a 790cc) it's very similar and it worked big time for me.
Make sure you've got a new drill bit and tha you fully centred and square on the hole. I used a pillar drill.
Your not drilling another hole your just making the existing hole 0.5 of a mm bigger in circcumforance.
Take it nice and esay as the metals very soft and keep the diaphrams well out of the way.
Falling that bike bandit sell the slide assembley with 3mm holes.
Look at part 6 on the schemeatic and scroll down to the price list, don't forget you'll need 2.
http://houseofmotorcycles.bikebandit...00/All/2291022
All the best
Jon (UK)
webonnielad is offline   Reply With Quote
Old 09-08-2007   #3 (permalink)
Favorite Bike: 2002 Triumph Bonneville
TheBoatDude's Avatar
Noob Question
I'm incredibly new to a) Motorcycles and b) Triumphs, so I apologize if this is an elementary question: What is this operation your referring to and what is it expected to do? I figure it is something to do with drilling a larger hole in a carburetor and fitting some sort of sliding mechanism, but that's where my technical knowledge dries up.
Thankx,
TBD
"...it's a Gin and Gin...it's like a Gin and Tonic, only you use Gin instead of Tonic..." --Dr. Caroline Todd, East Hampton Hospital Trust--
TheBoatDude is offline   Reply With Quote
Old 09-08-2007   #4 (permalink)
Favorite Bike: 04 thrux blk
Gohm's Avatar
Other Motorcycle: 06 klr 650 grn
It is enlarging the hole in the vacuum slide of the carb. It improves throttle response. You can do it at any point. You can either drill out the current hole larger to the correct size (offset vacuum hole, not the needle hole in the center!) or drill a second hole to equal size it total. If you do not like it, you can either replace the slide or fill in the hole and go back to stock size. there's some pix in my album for reference if you like.
Be a "weekend warrior" 7 days a week, 365 days a year!
My Photo Album
"A wink is as good as a nod to a blind bat" - MP
Gohm is offline   Reply With Quote
Old 09-09-2007   #5 (permalink)
stu
Favorite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 2002 Sprint ST
I have to be honest and say I didn't notice the least difference after the drilling.
You do have the potential to mess up the slide though. You could also shorten the spring a couple of turns to get the same effect.
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
stu is offline   Reply With Quote
Old 09-09-2007   #6 (permalink)
Favorite Bike: 2007 Bonnie Green
Other Motorcycle: 99 Kaw KLR650
I have an 07 bonnie with the 865 motor. I'm running TOR's, 118 mains, 3 turns, uni-filter, and the polaris bellmouth. The AI system and smog cannisters are gone. I drilled my slides to nearly 3 mm (7/64 inch bit), and didn't notice any change whatsoever. I've since removed the divider / restrictor plate in the air box, and what a huge difference that made! I've never done a dyno test, but now the tach shoots up when you twist the throttle like never before. The intake roar sound is also awesome now, the low end is still great, and my gas mileage is still in the high 40's (and occasionally in the low 50's).
My bike may be a little lean, but I'm having it checked on a dyno soon. I'm at 4000 feet altitude, which favors lean jetting. The needle in the carb on these 865 motors seems to be tremendously flexible, and you can use much smaller jets than with the 790 carb needle.
Based on my experience with the same motor and pipes, I wouldn't be afraid to drill the slides. Just don't expect any huge changes until that motor can really breath on the intake side.
Good luck!
Jim
2007 Bonnie Green. 865 cc motor with AI, emissions cannisters and airbox gone. NARK, 138/40 jets, 3 turns, 1 shim, slides drilled to 3mm. TORS, K/Q seat, sissy bar, 19T, and Parabellum windsceen.
JimSouba is offline   Reply With Quote
New Superbars - drill or file? justbrian Twins Technical Talk 3 01-12-2008 09:12 PM
Where do you drill? Xo_cet Twins Technical Talk 3 06-14-2007 03:13 AM
Best way to drill triple trees?? dardoonk Twins Talk 8 02-25-2006 07:06 PM
drill or not to drill? ozbon Twins Talk 10 02-01-2006 01:05 PM
How to drill out bolts? UJMrider Hinckley Classic Triples 12 08-12-2005 09:18 AM
